Can i get a line test
Fixes: 334
Re: Can i get a line test
I can't confirm/deny that - I'm on FTTP with Zen, so it wouldn't run for me now, but from memory when I was with Plusnet, it used to say either 'we have found no performance issues with your connection' or 'the tests were inconclusive, further investigation may be required' - or words to that effect. I never knew it to detail what it 'found'.
goldenfibre
Seasoned Pro
Fixes: 12
BTw Additional Diagnostics report out of curosity (it will not work on FTTP or SoGEA) it only work via FTTC with phone number only or G.Fast (SoGfast) I believed BTw are going to fix this soon for SoGEA.
Fixes: 89
@goldenfibre
It does work on FTTP - I tried it a few days ago using my BBEU number.
goldenfibre
Seasoned Pro
Fixes: 12
That's good to hear it. Mind you I don't have FTTP. I am on SoGfast and can confirmed it does work on BTw PT with BBEU number.
Fixes: 334
@bmc wrote:
@goldenfibre
So, I suspect the same can be said for SOGEA connections?
