Can i change my line from G.lite to ADSL2?
- Can i change my line from G.lite to ADSL2?
Re: Can i change my line from G.lite to ADSL2?
30-06-2008 9:12 AM
30-06-2008 9:19 AM
30-06-2008 9:21 AM
30-06-2008 9:35 AM
30-06-2008 9:47 AM
Could you try using the DMT Tool to force your noise margin to something lower such as 9dB to see if you have an improved connection speed whilst maintaining stability? Also, have you noticed your connection dropping out a bit recently (best to answer that question first before using DMT!)?
30-06-2008 9:48 AM
30-06-2008 9:50 AM
I think you missed the post on the previous page where there had clearly been a dropout.
Can you check the logs and advise the resent resynch times and speeds.
Taken from the earlier post
Quote Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 1888 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 350 kbps
Edit - I must type faster
30-06-2008 9:54 AM
30-06-2008 9:55 AM
30-06-2008 10:03 AM
headhunterhbn - You had various low speed resync events on Saturday and Sunday which are the reason for your speed problems. So basically, your problem isn't actually a speed one, but more one of a disconnecting nature which is subsequently causing your speeds to fall. The best thing to do in these cases (I appreciate that you have done a few of these already):
- Change filters
- Make sure that you are connected to your master/test socket directly via a filter
- Ensure that all of your used telephone sockets are filter
- Use/Borrow a different ADSL modem or router if possible to see if the disconnections still occur
Once you've tried all of the above, we can identify whether or not this is a line problem and raise to BT if this is the case.
30-06-2008 12:58 PM
30-06-2008 1:13 PM
30-06-2008 1:14 PM
30-06-2008 1:19 PM
I reckon you need to follow my suggestions above and then raise a fault if it continues.
30-06-2008 1:21 PM
