Can connect to some sites, but not others
WalnutTree
Hi, I've recently joined Plusnet and have had my broadband activated in the past few days. While I can browse to some websites, other websites completely fail to load. For example, I can view bbc.co.uk but can't connect to amazon.co.uk
A search on the PlusNet forums turned up this discussion which seems to match the problem I am encountering.
https://community.plus.net/forum/index.php/topic,139924.0.html
Could it be the same issue? I have the same router mentioned in the discussion ( PlusNet 2704n). Any help much appreciated. Many thanks.
Fixes: 219
Re: Can connect to some sites, but not others
I've made some changes from here.
Can you try resetting your router?
 Matthew Wheeler
WalnutTree
I've reset the router and sites are now loading fine. Many thanks  Smiley
