Can anyone tell me the cause of these disconnects?
- Re: Can anyone tell me the cause of these disconne...
08-08-2011 1:26 PM
I have a Billion 7800N and my line had been stable for around a month untill 2 disconnects, can anyone tell me if there are any clues in the log as to what caused them?
Aug 05 00:44:05 user kernel: Line 0: ADSL link down
Aug 05 00:44:05 user syslog: tc qdisc del dev ppp_0_0_38_1 root 2>/dev/null
Aug 05 00:44:06 user kernel: Line 0: xDSL G.994 training
Aug 05 00:44:08 daemon pppd[458]: Terminating connection due to link down.
Aug 05 00:44:12 user kernel: Line 0: ADSL G.992 started
Aug 05 00:44:15 user kernel: Line 0: ADSL G.992 channel analysis
Aug 05 00:44:19 user kernel: Line 0: ADSL G.992 message exchange
Aug 05 00:44:19 user kernel: Line 0: ADSL link up, interleaved, us=448, ds=7840
Aug 05 00:44:22 daemon pppd[458]: Clear IP addresses. Connection DOWN.
Aug 05 00:44:22 daemon pppd[458]: Couldn't increase MTU to 1500.
Aug 05 00:44:22 daemon pppd[458]: Connection terminated.
Aug 05 00:44:22 daemon pppd[458]: Connect time 37139.8 minutes.
Aug 05 00:44:22 daemon pppd[458]: Sent 2081723717 bytes, received 3118096201 bytes.
Aug 05 00:44:22 user kernel: dev_shutdown, dec ppp device refcnt, dev->refcnt=3
Aug 05 00:44:22 user kernel: unregister_netdevice: waiting for ppp_0_0_38_1 to become free. Usage count = -1
Aug 05 00:44:22 user kernel: dev->name = ppp_0_0_38_1, dev->refcnt=-1
Aug 05 00:44:22 user kernel: after reset to 0, dev->refcnt=0
Aug 05 00:44:22 daemon pppd[458]: PPP: Start to connect ...
Aug 05 00:44:24 daemon pppd[458]: Using interface ppp0_0_38_1
Aug 05 00:44:24 daemon pppd[458]: Connect: ppp_0_0_38_1 <-->
Aug 05 00:44:24 daemon pppd[458]: Couldn't increase MTU to 1500.
Aug 05 00:44:27 daemon pppd[458]: PPP LCP UP.
Aug 05 00:44:27 daemon pppd[458]: Couldn't increase MTU to 1500.
Aug 05 00:44:28 daemon pppd[458]: local IP address xxx.xxx.xxx.xxx
Aug 05 00:44:28 daemon pppd[458]: remote IP address 195.166.128.232
Aug 05 00:44:28 daemon pppd[458]: primary DNS address 212.159.6.9
Aug 05 00:44:28 daemon pppd[458]: secondary DNS address 212.159.6.10
Aug 05 00:44:28 daemon dnsmasq[92]: using nameserver 212.159.6.10#53
Aug 05 00:44:28 daemon dnsmasq[92]: using nameserver 212.159.6.9#53
Aug 05 00:44:28 daemon pppd[458]: Received valid IP address from server. Connection UP.
Aug 05 00:44:28 user syslog: begin: interface: ppp_0_0_38_1 go to up
Aug 05 00:44:28 daemon UPNPD[7388]: received signal 15, good-bye
Aug 05 00:44:30 daemon UPNPD[8464]: HTTP listening on port 2800
Aug 05 00:44:32 user syslog: end: interface: ppp_0_0_38_1 go to up
Aug 05 00:59:34 syslog -- MARK --
Aug 07 05:59:33 syslog -- MARK --
Aug 07 06:15:05 daemon pppd[458]: LCP terminated by peer
Aug 07 06:15:05 daemon pppd[458]: Clear IP addresses. Connection DOWN.
Aug 07 06:15:05 daemon pppd[458]: Couldn't increase MTU to 1500.
Aug 07 06:15:06 user syslog: begin: interface: ppp_0_0_38_1 go to down
Aug 07 06:15:06 user syslog: end: interface: ppp_0_0_38_1 go to down
Aug 07 06:15:08 daemon pppd[458]: Connection terminated.
Aug 07 06:15:08 daemon pppd[458]: Connect time 3210.8 minutes.
Aug 07 06:15:08 daemon pppd[458]: Sent 145918493 bytes, received 665423623 bytes.
Aug 07 06:15:08 user kernel: dev_shutdown, dec ppp device refcnt, dev->refcnt=3
Aug 07 06:15:09 user kernel: unregister_netdevice: waiting for ppp_0_0_38_1 to become free. Usage count = -1
Aug 07 06:15:09 user kernel: dev->name = ppp_0_0_38_1, dev->refcnt=-1
Aug 07 06:15:09 user kernel: after reset to 0, dev->refcnt=0
Aug 07 06:15:12 daemon pppd[458]: PPP: Start to connect ...
Aug 07 06:15:13 daemon pppd[458]: Using interface ppp0_0_38_1
Aug 07 06:15:13 daemon pppd[458]: Connect: ppp_0_0_38_1 <-->
Aug 07 06:15:13 daemon pppd[458]: Couldn't increase MTU to 1500.
Aug 07 06:15:16 daemon pppd[458]: PPP LCP UP.
Aug 07 06:15:17 daemon pppd[458]: Couldn't increase MTU to 1500.
Aug 07 06:15:17 daemon pppd[458]: PPP LCP UP.
Aug 07 06:15:17 daemon pppd[458]: local IP address xxx.xxx.xxx.xxx
Aug 07 06:15:17 daemon pppd[458]: remote IP address 195.166.128.229
Aug 07 06:15:17 daemon pppd[458]: primary DNS address 212.159.6.9
Aug 07 06:15:17 daemon pppd[458]: secondary DNS address 212.159.6.10
Aug 07 06:15:18 daemon dnsmasq[92]: using nameserver 212.159.6.10#53
Aug 07 06:15:18 daemon dnsmasq[92]: using nameserver 212.159.6.9#53
Aug 07 06:15:18 daemon pppd[458]: Received valid IP address from server. Connection UP.
Aug 07 06:15:18 user syslog: begin: interface: ppp_0_0_38_1 go to up
Aug 07 06:15:18 daemon UPNPD[8464]: received signal 15, good-bye
Aug 07 06:15:20 daemon UPNPD[8902]: HTTP listening on port 2800
Aug 07 06:15:22 user syslog: end: interface: ppp_0_0_38_1 go to up
Aug 07 06:59:33 syslog -- MARK --
Steve
Re: Can anyone tell me the cause of these disconnects?
08-08-2011 1:55 PM
Quote from: SteveArnold
To use a telephone call analogy, in the first instance it looks like the line went dead. In the second instance does "terminated by peer" mean that Plusnet did the broadband equivalent of putting the phone down on you?
08-08-2011 4:31 PM
ReedRichards is on the money above^
They're both nothing really to worry about, the first was probably caused by routine BT maintenance tbh (seen as its between 00:00 and 03:00) -- although the connection came back very quickly (could of been just a random blip though)
the second was probably either the same as above - or:
a) pn maintenance
b) DLM changing your profile/line settings
c)pn changing your ip/traffic management profile
d) completely random one-off event
I certainly wouldnt be too concerned, around 1 month uptime is absolutely fantastic tbh.
Quote System Up-Time 26 Day(s) 0 Hour(s)
^^ my 7800n
Regards
08-08-2011 5:24 PM
I've checked our connection logs for your line and the amount and frequency of disconnections are nothing to worry at the moment. See below:
Certainly monitor this however and let us know if they continue/get worse.
09-08-2011 12:29 PM
Thanks for the replies, 25 days is a record my previous best IIRC is around 8 days.
The only moan I have about the 7800N is the log only appears to hold around 4 days entries, records a --mark-- every hour and theres no way to have it send a email if there is a disconnect, unless anyone knows otherwise?
Steve
09-08-2011 12:40 PM
This means that you can get it to send those "logs" to another machine (provided the receiving machine is on of course!) which will add the lines to a database (dependant on what software you use)
This means you can scroll through the logs, and see "what happened" even if the router reboots unexpectedly!
Regards
09-08-2011 1:16 PM
It appears I had another disconnect:
Aug 08 22:54:08 user kernel: Line 0: ADSL link down
Aug 08 22:54:08 user syslog: tc qdisc del dev ppp_0_0_38_1 root 2>/dev/null
Aug 08 22:54:09 user kernel: Line 0: xDSL G.994 training
Aug 08 22:54:10 daemon pppd[9175]: Terminating connection due to link down.
Aug 08 22:54:15 user kernel: Line 0: ADSL G.992 started
Aug 08 22:54:17 user kernel: Line 0: ADSL G.992 channel analysis
Aug 08 22:54:22 user kernel: Line 0: ADSL link up, interleaved, us=448, ds=8128
Aug 08 22:54:24 daemon pppd[9175]: Clear IP addresses. Connection DOWN.
Aug 08 22:54:24 daemon pppd[9175]: Couldn't increase MTU to 1500.
Aug 08 22:54:24 daemon pppd[9175]: Connection terminated.
Aug 08 22:54:24 daemon pppd[9175]: Connect time 592.4 minutes.
Aug 08 22:54:24 daemon pppd[9175]: Sent 38232711 bytes, received 1593277881 bytes.
Aug 08 22:54:24 user kernel: dev_shutdown, dec ppp device refcnt, dev->refcnt=3
Aug 08 22:54:24 user kernel: unregister_netdevice: waiting for ppp_0_0_38_1 to become free. Usage count = -1
Aug 08 22:54:24 user kernel: dev->name = ppp_0_0_38_1, dev->refcnt=-1
Aug 08 22:54:24 user kernel: after reset to 0, dev->refcnt=0
Aug 08 22:54:24 daemon pppd[9175]: PPP: Start to connect ...
Aug 08 22:54:26 daemon pppd[9175]: Using interface ppp0_0_38_1
Aug 08 22:54:26 daemon pppd[9175]: Connect: ppp_0_0_38_1 <-->
Aug 08 22:54:26 daemon pppd[9175]: Couldn't increase MTU to 1500.
Aug 08 22:54:29 daemon pppd[9175]: PPP LCP UP.
Aug 08 22:54:29 daemon pppd[9175]: Couldn't increase MTU to 1500.
Aug 08 22:54:30 daemon pppd[9175]: local IP address xxx.xxx.xxx.xxx
Aug 08 22:54:30 daemon pppd[9175]: remote IP address 195.166.128.239
Aug 08 22:54:30 daemon pppd[9175]: primary DNS address 212.159.6.9
Aug 08 22:54:30 daemon pppd[9175]: secondary DNS address 212.159.6.10
Aug 08 22:54:30 daemon dnsmasq[92]: using nameserver 212.159.6.10#53
Aug 08 22:54:30 daemon dnsmasq[92]: using nameserver 212.159.6.9#53
Aug 08 22:54:30 daemon pppd[9175]: Received valid IP address from server. Connection UP.
Aug 08 22:54:30 user syslog: begin: interface: ppp_0_0_38_1 go to up
Aug 08 22:54:30 daemon UPNPD[9982]: received signal 15, good-bye
Can anyone recommend software to use with the syslog function that Matt_2k34 mentions?
I was hoping for something similar to my old Netgear DG834N which could be setup to email the logs hourly/daily or if the 7800N had a option to choose what entries are made to the log would have been ideal.
By the way I'm running 1.06b firmware, didn't see any real need to update - if it ain't broke don't fix it.
Steve
09-08-2011 1:59 PM
09-08-2011 3:15 PM
Steve
09-08-2011 7:44 PM
Quote Can anyone recommend software to use with the syslog function that Matt_2k34 mentions?
You need a syslog server, just google it and you'll see various ones available for free depending on which OS you use.
09-08-2011 9:25 PM
Steve
