Can anyone helpme change my DNS settings on the router?
- Re: Can anyone helpme change my DNS settings on th...
29-01-2014 8:33 PM
Hi I'm wanting to try the US version of Netflix and wondered how you go about changing the DNS settings on the router? A simple step by step would be appreciated! Thanks
Message 1 of 6
(2,312 Views)
5 REPLIES 5
Re: Can anyone helpme change my DNS settings on the router?
29-01-2014 8:48 PM
(Assuming it's a TG582n router)
http://www.petecooper.org/tutorials/changing-dns-servers-on-a-technicolor-tg582n-fttc
Message 2 of 6
(1,158 Views)
29-01-2014 9:47 PM
Why not add entries to the PCs host file to override the DNS for the particular host addresses?
Message 3 of 6
(1,158 Views)
30-01-2014 7:52 PM
JEEEESUS!!!!
Yes that's my router allright! I thought it would be just[i a matter of logging into the router and adding the DNS settings!
Not sure I'm confident enough to do that but thanks for the reply I appreciate it
Jelv
Would you explain your suggestion please? I have Netflix on my Roku 2XS it's wired direct to the router and this DNS thing is what I need to do....
Jelv
Message 4 of 6
(1,158 Views)
30-01-2014 9:21 PM
Ah! I had to look to see what a Roku 2XS was - I'd be surprised if you could do it on that. I was assuming you'd be on a PC of some sort.
Message 5 of 6
(1,158 Views)
06-03-2014 3:29 PM
Quote from: ivesy Hi I'm wanting to try the US version of Netflix and wondered how you go about changing the DNS settings on the router? A simple step by step would be appreciated! Thanks
What are you using to watch nf? (just seen its a roku, if there is a option to change the dns in the options, just do that)
on a wd tv box for example just change the dns in options
if your using a pc or smarter tv box that runs android (MINIX NEO X7 is the best tv box out there as it will do everything a tv box and pc, phone can do ) get a vpn or go in to windows network connections, internet protocol v 4 ipv4 and fill out the " use the following dns server"
that's all you need to do
just remember to put the dns back when your done
there are loads of free dns's out there for the usa to allow nf and hulu
or you can pay for a dns and or a vpn for £20-£30 py
Message 6 of 6
(1,158 Views)
