Can anyone from Plusnet help please?
- Can anyone from Plusnet help please?
04-11-2010 5:16 PM
My ip profile is 9747 but Plusnet is stuck at 6500. Is there any chance of a nudge? I've had this profile for over 3 days and before I lost connection over 3 days ago I had the same profile of 9747 but I seem to be stuck on 6500. I think I should be on at least 8000. See details below,
Uptime: 3 days, 14:07:50
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 9,747
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 2.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 19.5 / 42.5
Message 1 of 4
(737 Views)
3 REPLIES 3
Re: Can anyone from Plusnet help please?
04-11-2010 5:28 PM
Hi BLINDPEW,
That's now been done for you Your profile on BTs side is at 8000 so I've upped it on our side to match.
Message 2 of 4
(361 Views)
04-11-2010 5:30 PM
There is no such IP profile as 9747 - that is your sync speed.
For that sync speed your IP Profile should be 8000. To get a profile of 9000 you would need to be consistently syncing at 10208 or higher.
Message 3 of 4
(361 Views)
04-11-2010 6:39 PM
Thanks for that Matt, I'm glad you knew what I meant.
Message 4 of 4
(361 Views)
