Can a rep help this poster
reserved
This guy could do with some help please.
5 REPLIES 5
Fixes: 392
Re: Can a rep help this poster
They already are, here http://community.plus.net/forum/index.php/topic,128678.0.html
reserved
Confused, different user name!!
RPMozley
Fixes: 13
Can we really be sure it is the same person?
That's RPM to you!!
pwatson
From Thinkbroadband
Logged a query on the PlusNet Forum and was told the phone line will switch on the 11th and the Fibre would commence on 23rd.
I can't see any other posts on here mentioning those dates?
RPMozley
Fixes: 13
Ah, must have missed that bit in the other forum or it was added later on after I looked.  Roll_eyes
That's RPM to you!!
