Can You....
- Can You....
Can You....
04-10-2007 11:27 AM
please change my speed's back upto 4500 as that's what it was before I downgraded to option 2 then upgraded back to option 3, as i was getting lovely steady 4.2 mbps speeds until saturday's change over.
regards
regards
Message 1 of 4
(1,232 Views)
3 REPLIES 3
Re: Can You....
04-10-2007 11:30 AM
What are you syncing at to the exchange as that determines your speed, not PlusNet.
Message 2 of 4
(360 Views)
Re: Can You....
04-10-2007 11:38 AM
Hi Jules,
You're actually still on a 4.5MB profile our side, can you let us know what sync speed you are getting, or run a BT Speedtest for me please?
Message 3 of 4
(360 Views)
Re: Can You....
04-10-2007 2:54 PM
I was most definately only on a 4 mb profile when i posted..
BT speedtest....
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 4500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5568 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3614 kbps
Profile now does state 4.5 mbps
BT speedtest....
Message 4 of 4
(360 Views)
