Can Plusnet raise my profile please?
- Can Plusnet raise my profile please?
01-05-2010 3:43 PM
I have a constant connection of 7.2MB, not sure why my ip profile has dropped to 6MB. Restarted the router today after 11 days of steady 7.2Mb sync, but no change unfortunately.
Download speedachieved during the test was - 4148 Kbps
Additional Information:
Your DSL Connection Rate :7264 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6000 Kbps
Message 1 of 3
(771 Views)
2 REPLIES 2
Re: Can Plusnet raise my profile please?
01-05-2010 11:22 PM
Unfortunately the IP Profile that goes with a sync speed of 7264kbps is 6000kbps. You need to sync at 7392kbps or higher to get an IP Profile of 6500kbps (link).
David
Message 2 of 3
(359 Views)
02-05-2010 9:38 AM
That would explain it.
Thanks for the clarification.
Message 3 of 3
(359 Views)
