Can I use an old plusnet router
LizzyJ
I've just moved into a new flat, my plusnet broadband has gone live but my router hasn't arrived! The last person left a plusnet router behind, can I use this whilst I wait for mine? I tried plugging it in but the internet light stays red. Help!
8 REPLIES 8
mort7890
Fixes: 4
Re: Can I use an old plusnet router
You will need to set it up with your details
LizzyJ
Ok, how do I do that?
mort7890
Fixes: 4
Go to the settings of the router and change them to your account
LizzyJ
And how do I do that?
Alex
Fixes: 13
What model of router do you currently have?
There should be a label on it somewhere - if you post a photo we can help.
I could be wrong but I think some routers are on the 0 subnet and some are on the 1.
So try browsing to:
192.168.0.1
or
192.168.1.1
Hopefully you'll find a login page on either of those, and the password may be on the router. Again hopefully it hadn't been changed and you can get into the router settings.
mort7890
Fixes: 4
It could also be on either 192.168.1.254 or 192.168.0.254
mort7890
Fixes: 4
It usually gives instructions on the back or underneath
Alex
Fixes: 13
Thanks @mort7890
I am not at my sisters (who uses PlusNet) so can't check.
Only other thing I can think of which may be a problem - did the OP order Fibre?
It is possible then you need a VDSL router and not just an ADSL one.
If you can confirm whether you did, and some information on the model of the router you currently have we can help.
