Can I use TG585 as a wireless access point?
- Can I use TG585 as a wireless access point?
- « Previous
- 1
- 2
- Next »
Re: Can I use TG585 as a wireless access point?
29-02-2012 10:26 PM
Quote the 585 seems to give his hardware new ips
That means that DHCP is not off on the 585.
Login and check this.
Ian
Message 16 of 17
(1,346 Views)
29-02-2012 10:32 PM
I think ive solved it. Dhcp was off on the 585 i think it was because i set the ip range on the netgear to start after the ip range i had reserved for some hardware if that makes sense.
Message 17 of 17
(1,346 Views)
- « Previous
- 1
- 2
- Next »
