Can I request a profile reset please?
- Can I request a profile reset please?
Re: Can I request a profile reset please?
21-06-2019 11:08 AM
Absolutely gutted.
I'm getting the same periodic disconnects according to the system logs. TP-Link have not been helpful via support. So I'm not sure of the way forward. The new router is doing the same thing as the old. I'm wondering if there's a power issue on my sockets or if there's an issue with the chipsets in the two TP-Link routers I've tried. Here's my log if anyone can interpret.
ID | Time | Type | Level | Log Content |
1 | 2019-06-21 09:14:47 | PPP | Error | ppp1 |
2 | 2019-06-21 09:14:47 | PPP | Error | ppp1 User request |
3 | 2019-06-21 09:14:43 | PPP | Error | ppp1 LCP down |
4 | 2019-06-21 09:14:43 | PPP | Error | ppp1 User request |
5 | 2019-06-21 09:12:49 | PPP | Error | ppp1 |
6 | 2019-06-21 09:12:49 | PPP | Error | ppp1 User request |
7 | 2019-06-21 09:12:45 | PPP | Error | ppp1 LCP down |
8 | 2019-06-21 09:12:45 | PPP | Error | ppp1 User request |
21-06-2019 11:16 AM
As suggested above, now you have tried an alternative router, you need to complete the fault report please.
21-06-2019 11:44 AM
I've raised the fault with Plusnet.
21-06-2019 12:41 PM
Thanks for raising the fault Dean.
I've added a reply to your fault ticket which you can view from Here however for visibility in case anyone on here have any ideas or can help, what I've done is order you a new router to try to narrow down where the issue lies.
While not always indicative of a router fault, our records are showing your connection dropping due to "User Request" so before we go down the route of an engineer visit I'd like to rule out the issue to be with your TP Link router/settings even though I understand you've tried two, and any internal wiring to be the cause for the issue.
Your new router will come with a new microfilter and should arrive within the next few days.
Once you've received it could you connect it into the test socket as explained Here please? I'd also recommend letting us know over here when you've done this as we'll need to reset your line to remove the speed restrictions applied automatically, then you'll need to monitor things and see how they go.
If this resolves the issue then we'll need to put things back how they were one at a time to try to figure out what was causing the problem. If you are however still experiencing connection issues, following the above steps we'd need to arrange an engineer to investigate this so I'd recommend replying to the ticket with your availability and we'll get it booked in.
Let us know how it goes. Hope this helps.
21-06-2019 12:57 PM
Dean,
Which TP router?
Can you turn on all of the diagnostics please in the logging?
I have a vague recollection of seeing a TP router I used once dropping the connection and reporting "User Request" as the reason. Some time ago, slept a bit since then and I do not have access to that router / user any more.
on 22-06-2019 7:26 AM - last edited on 22-06-2019 8:53 AM by dvorak
The first router was a TP-Link TD-w8970 and the replacement one is a TP-Link VR2800. Here's the complete log for the last day or so.
2019-06-21 11:43:10 [5] Httpd: Clear log.
2019-06-21 11:45:23 [5] DHCPD: Recv REQUEST from 88:71:E5:E3:E0:75
2019-06-21 11:45:24 [5] DHCPD: Send ACK to 192.168.1.109
2019-06-21 12:04:44 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 12:04:44 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 12:04:44 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 12:04:45 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 12:19:15 [5] System: LAN1 link down
2019-06-21 12:19:17 [5] System: LAN1 link up 10 mbps
2019-06-21 12:37:36 [3] PPP: ppp1 User request
2019-06-21 12:37:36 [3] PPP: ppp1 LCP down
2019-06-21 12:37:36 [4] PPP: ppp1 LCP down
2019-06-21 12:37:36 [6] PPP: ppp1 sent [LCP TermReq id=0x2 "User request"]
2019-06-21 12:37:36 [6] PPP: ppp1 sent [LCP TermReq id=0x3 "User request"]
2019-06-21 12:37:42 [3] PPP: ppp1 User request
2019-06-21 12:38:00 [6] PPP: ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x86e5b2bc>]
2019-06-21 12:38:00 [6] PPP: ppp1 rcvd [LCP ConfReq id=0x65 <mru 1500> <auth chap MD5> <magic 0x3352228e>] 00 00 00 00 00 00
2019-06-21 12:38:00 [6] PPP: ppp1 sent [LCP ConfAck id=0x65 <mru 1500> <auth chap MD5> <magic 0x3352228e>]
2019-06-21 12:38:00 [6] PPP: ppp1 rcvd [LCP ConfAck id=0x1 <mru 1480> <magic 0x86e5b2bc>] 00 00 00 00 00 00 00 00 00 00 00 00
2019-06-21 12:38:00 [6] PPP: ppp1 sent [LCP EchoReq id=0x0 magic=0x86e5b2bc]
2019-06-21 12:38:00 [6] PPP: ppp1 rcvd [CHAP Challenge id=0x1 <7f9bd2c832a77a64ebe273b755e5b54f2d7fc57491f8690cf8d1adc5215aae
2019-06-21 12:38:00 [6] PPP: ppp1 sent [CHAP Response id=0x1 <2e141b2ddf46353a05e1b009e14839c7>, name = " [Removed]@plusdsl
2019-06-21 12:38:00 [6] PPP: ppp1 rcvd [LCP EchoRep id=0x0 magic=0x3352228e] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2019-06-21 12:38:00 [6] PPP: ppp1 rcvd [CHAP Success id=0x1 "CHAP authentication success"] 00 60 06 70 58 54 00 63 52 00 00 8
2019-06-21 12:38:00 [6] PPP: ppp1 sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0
2019-06-21 12:38:00 [6] PPP: ppp1 rcvd [IPCP ConfReq id=0x7e <addr 172.16.16.49>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0
2019-06-21 12:38:00 [6] PPP: ppp1 sent [IPCP ConfAck id=0x7e <addr 172.16.16.49>]
2019-06-21 12:38:00 [6] PPP: ppp1 rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2019-06-21 12:38:00 [6] PPP: ppp1 sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
2019-06-21 12:38:00 [6] PPP: ppp1 rcvd [IPCP ConfNak id=0x2 <addr 146.90.204.204> <ms-dns1 212.159.6.9> <ms-dns2 212.159.6.10
2019-06-21 12:38:00 [6] PPP: ppp1 sent [IPCP ConfReq id=0x3 <addr 146.90.204.204> <ms-dns1 212.159.6.9> <ms-dns2 212.159.6.10
2019-06-21 12:38:00 [6] PPP: ppp1 rcvd [IPCP ConfAck id=0x3 <addr 146.90.204.204> <ms-dns1 212.159.6.9> <ms-dns2 212.159.6.10
2019-06-21 12:43:47 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 12:43:47 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 12:43:47 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 12:43:48 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 12:47:50 [5] System: LAN1 link down
2019-06-21 12:47:53 [5] System: LAN1 link up 1000 mbps
2019-06-21 12:47:56 [5] DHCPD: Recv REQUEST from D8:50:E6:56:C5:D9
2019-06-21 12:47:56 [5] DHCPD: Send ACK to 192.168.1.112
2019-06-21 13:48:20 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 13:48:20 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 13:48:25 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 13:48:25 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 13:48:25 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 13:48:26 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 13:57:21 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 13:57:21 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 13:57:26 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 13:57:26 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 13:57:33 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 13:57:33 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 13:57:34 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 13:57:34 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 14:07:59 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 14:07:59 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 14:07:59 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 14:08:00 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 14:14:49 [5] System: LAN1 link down
2019-06-21 14:14:50 [5] System: LAN1 link up 10 mbps
2019-06-21 14:16:01 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 14:16:01 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 14:16:01 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 14:16:02 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 14:29:47 [5] DHCPD: Recv REQUEST from 60:A4:4C:64:12:E7
2019-06-21 14:29:47 [5] DHCPD: Send ACK to 192.168.1.115
2019-06-21 14:50:01 [5] System: LAN1 link down
2019-06-21 14:50:03 [5] System: LAN1 link up 1000 mbps
2019-06-21 14:50:03 [5] DHCPD: Recv REQUEST from D8:50:E6:56:C5:D9
2019-06-21 14:50:03 [5] DHCPD: Send ACK to 192.168.1.112
2019-06-21 16:13:35 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:13:35 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:13:40 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:13:40 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:14:02 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:14:02 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:14:13 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:14:13 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:14:26 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:14:26 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:14:42 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:14:42 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:15:12 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:15:12 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:15:12 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:15:12 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:26:30 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:26:30 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:26:30 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:26:31 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:26:35 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:26:36 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:26:40 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:26:41 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:26:48 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:26:48 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:26:53 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:26:53 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:26:58 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:26:58 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:27:09 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:27:09 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:27:09 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:27:10 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:27:14 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:27:15 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:27:19 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:27:20 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:30:26 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:30:26 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:30:26 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:30:27 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:41:01 [5] System: LAN1 link down
2019-06-21 16:41:03 [5] System: LAN1 link up 10 mbps
2019-06-21 16:47:28 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:47:28 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:47:33 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:47:33 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:47:41 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:47:41 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:47:41 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:47:41 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:49:40 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 16:49:40 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 16:49:40 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 16:49:41 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 16:58:07 [5] System: LAN1 link down
2019-06-21 16:58:10 [5] System: LAN1 link up 1000 mbps
2019-06-21 16:58:13 [5] DHCPD: Recv REQUEST from D8:50:E6:56:C5:D9
2019-06-21 16:58:13 [5] DHCPD: Send ACK to 192.168.1.112
2019-06-21 17:00:56 [5] DHCPD: Recv DISCOVER from 64:A2:F9:17:C2:8F
2019-06-21 17:00:56 [5] DHCPD: Send OFFER with ip 192.168.1.104
2019-06-21 17:00:56 [5] DHCPD: Recv REQUEST from 64:A2:F9:17:C2:8F
2019-06-21 17:00:56 [5] DHCPD: Send ACK to 192.168.1.104
2019-06-21 17:05:30 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 17:05:30 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 17:05:31 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 17:05:31 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 17:56:36 [5] System: LAN1 link down
2019-06-21 17:56:38 [5] System: LAN1 link up 10 mbps
2019-06-21 18:19:06 [5] System: LAN1 link down
2019-06-21 18:19:09 [5] System: LAN1 link up 1000 mbps
2019-06-21 18:19:12 [5] DHCPD: Recv REQUEST from D8:50:E6:56:C5:D9
2019-06-21 18:19:12 [5] DHCPD: Send ACK to 192.168.1.112
2019-06-21 18:43:23 [5] DHCPD: Recv REQUEST from 3C:5C:C4:D8:8F:58
2019-06-21 18:43:23 [5] DHCPD: Send ACK to 192.168.1.106
2019-06-21 18:56:46 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 18:56:46 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 18:56:46 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 18:56:46 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 19:07:54 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 19:07:54 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 19:07:54 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 19:07:55 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 19:12:34 [5] DHCPD: Recv REQUEST from 00:23:24:14:FA:0A
2019-06-21 19:12:34 [5] DHCPD: Send ACK to 192.168.1.108
2019-06-21 19:54:15 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 19:54:15 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 19:54:15 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 19:54:16 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 20:23:36 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 20:23:36 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 20:23:36 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 20:23:37 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 20:23:41 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 20:23:42 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 20:23:54 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 20:23:54 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 20:23:59 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 20:23:59 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 20:23:59 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 20:24:00 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 20:24:04 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 20:24:05 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 20:24:09 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 20:24:10 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 20:24:17 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 20:24:17 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 20:24:19 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 20:24:19 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 20:24:19 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 20:24:20 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 20:24:24 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 20:24:25 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 20:24:53 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 20:24:53 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 20:24:53 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 20:24:53 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 20:46:35 [5] DHCPD: Recv REQUEST from 00:90:A9:6F:63:FD
2019-06-21 20:46:35 [5] DHCPD: Send ACK to 192.168.1.100
2019-06-21 20:50:20 [5] System: LAN4 link down
2019-06-21 20:53:17 [5] DHCPD: Recv REQUEST from 68:9A:87:50:6E:FE
2019-06-21 20:53:17 [5] DHCPD: Send ACK to 192.168.1.102
2019-06-21 20:53:21 [5] DHCPD: Recv REQUEST from 68:9A:87:4D:74:FE
2019-06-21 20:53:21 [5] DHCPD: Send ACK to 192.168.1.103
2019-06-21 21:04:35 [5] DHCPD: Recv DISCOVER from 64:A2:F9:17:C2:8F
2019-06-21 21:04:35 [5] DHCPD: Send OFFER with ip 192.168.1.104
2019-06-21 21:04:35 [5] DHCPD: Recv REQUEST from 64:A2:F9:17:C2:8F
2019-06-21 21:04:36 [5] DHCPD: Send ACK to 192.168.1.104
2019-06-21 21:10:36 [5] System: LAN1 link down
2019-06-21 21:10:37 [5] System: LAN1 link up 10 mbps
2019-06-21 21:30:47 [5] DHCPD: Recv REQUEST from B0:05:94:23:D0:81
2019-06-21 21:30:47 [5] DHCPD: Send ACK to 192.168.1.101
2019-06-21 21:37:43 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 21:37:43 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 21:38:15 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 21:38:15 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 21:38:15 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 21:38:15 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-21 21:43:00 [5] System: LAN1 link down
2019-06-21 21:43:03 [5] System: LAN1 link up 1000 mbps
2019-06-21 21:43:07 [5] DHCPD: Recv REQUEST from D8:50:E6:56:C5:D9
2019-06-21 21:43:07 [5] DHCPD: Send ACK to 192.168.1.112
2019-06-21 22:20:59 [5] System: LAN1 link down
2019-06-21 22:21:01 [5] System: LAN1 link up 10 mbps
2019-06-21 22:39:04 [5] DHCPD: Recv REQUEST from 04:03:D6:53:2E:D0
2019-06-21 22:39:04 [5] DHCPD: Send ACK to 192.168.1.107
2019-06-21 23:14:10 [5] DHCPD: Recv REQUEST from 3C:5C:C4:D8:8F:58
2019-06-21 23:14:10 [5] DHCPD: Send ACK to 192.168.1.106
2019-06-21 23:16:37 [5] DHCPD: Recv REQUEST from 88:71:E5:E3:E0:75
2019-06-21 23:16:38 [5] DHCPD: Send ACK to 192.168.1.109
2019-06-21 23:53:46 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 23:53:46 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 23:53:51 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-21 23:53:51 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-21 23:53:51 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-21 23:53:52 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-22 01:29:18 [5] DHCPD: Recv REQUEST from 3C:5C:C4:D8:8F:58
2019-06-22 01:29:18 [5] DHCPD: Send ACK to 192.168.1.106
2019-06-22 02:40:14 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-22 02:40:14 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-22 02:40:19 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-22 02:40:19 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-22 02:40:28 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-22 02:40:28 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-22 02:40:43 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-22 02:40:43 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-22 02:40:43 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-22 02:40:44 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-22 03:44:19 [5] DHCPD: Recv REQUEST from 3C:5C:C4:D8:8F:58
2019-06-22 03:44:19 [5] DHCPD: Send ACK to 192.168.1.106
2019-06-22 04:06:46 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-22 04:06:46 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-22 04:06:51 [5] DHCPD: Recv DISCOVER from AA:A0:01:0B:BB:6E
2019-06-22 04:06:51 [5] DHCPD: Send OFFER with ip 192.168.1.105
2019-06-22 04:06:51 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-22 04:06:51 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-22 04:06:56 [5] DHCPD: Recv REQUEST from AA:A0:01:0B:BB:6E
2019-06-22 04:06:56 [5] DHCPD: Send ACK to 192.168.1.105
2019-06-22 05:59:27 [5] DHCPD: Recv REQUEST from 3C:5C:C4:D8:8F:58
2019-06-22 05:59:27 [5] DHCPD: Send ACK to 192.168.1.106
2019-06-22 06:29:38 [5] System: LAN1 link down
2019-06-22 06:29:40 [5] System: LAN1 link up 1000 mbps
2019-06-22 06:29:40 [5] DHCPD: Recv REQUEST from D8:50:E6:56:C5:D9
2019-06-22 06:29:40 [5] DHCPD: Send ACK to 192.168.1.112
2019-06-22 06:41:22 [6] PPP: ppp1 rcvd [LCP TermReq id=0x1] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2019-06-22 06:41:22 [3] PPP: ppp1 LCP down
2019-06-22 06:41:22 [4] PPP: ppp1 LCP down
2019-06-22 06:41:22 [6] PPP: ppp1 sent [LCP TermAck id=0x1]
2019-06-22 06:41:29 [3] PPP: ppp1 User request
2019-06-22 06:41:31 [5] System: DSL Link Down
2019-06-22 06:41:32 [5] System: DSL Training G.994
2019-06-22 06:41:43 [5] System: DSL G.994 Non-Standard Info Received
2019-06-22 06:41:45 [5] System: DSL G.994 Non-Standard Info Received
2019-06-22 06:41:47 [5] System: DSL Training G.992 Started
2019-06-22 06:41:51 [5] System: DSL Training G.992 Channel Analysis
2019-06-22 06:41:57 [5] System: DSL Training G.992 Exchange
2019-06-22 06:41:59 [5] System: DSL Training G.994
2019-06-22 06:42:09 [5] System: DSL G.994 Non-Standard Info Received
2019-06-22 06:42:12 [5] System: DSL G.994 Non-Standard Info Received
2019-06-22 06:42:12 [5] System: DSL Training G.992 Started
2019-06-22 06:42:17 [5] System: DSL Training G.992 Channel Analysis
2019-06-22 06:42:23 [5] System: DSL Training G.992 Exchange
2019-06-22 06:42:24 [5] System: DSL Link Up us/ds 1085/4543 kbps Type ATM
2019-06-22 06:42:28 [6] PPP: ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x573dc2b9>]
2019-06-22 06:42:31 [6] PPP: ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x573dc2b9>]
2019-06-22 06:42:34 [6] PPP: ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x573dc2b9>]
2019-06-22 06:42:37 [6] PPP: ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x573dc2b9>]
2019-06-22 06:42:40 [6] PPP: ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x573dc2b9>]
2019-06-22 06:42:43 [6] PPP: ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x573dc2b9>]
2019-06-22 06:42:46 [6] PPP: ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x573dc2b9>]
2019-06-22 06:42:49 [6] PPP: ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x573dc2b9>]
2019-06-22 06:42:49 [6] PPP: ppp1 rcvd [LCP ConfReq id=0x85 <mru 1500> <auth chap MD5> <magic 0x4b8441c2>] 00 00 00 00 00 00
2019-06-22 06:42:49 [6] PPP: ppp1 sent [LCP ConfAck id=0x85 <mru 1500> <auth chap MD5> <magic 0x4b8441c2>]
2019-06-22 06:42:49 [6] PPP: ppp1 rcvd [LCP ConfAck id=0x1 <mru 1480> <magic 0x573dc2b9>] 00 00 00 00 00 00 00 00 00 00 00 00
2019-06-22 06:42:49 [6] PPP: ppp1 sent [LCP EchoReq id=0x0 magic=0x573dc2b9]
2019-06-22 06:42:49 [6] PPP: ppp1 rcvd [CHAP Challenge id=0x1 <588864576084e8e05bb59df4b6d7ca8bed3b5f6a858da984c0141b7cdb747f
2019-06-22 06:42:49 [6] PPP: ppp1 sent [CHAP Response id=0x1 <d326f4ff7a9302adb0de9b0cd39ba3a9>, name = " [Removed]@plusdsl
2019-06-22 06:42:49 [6] PPP: ppp1 rcvd [LCP EchoRep id=0x0 magic=0x4b8441c2] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2019-06-22 06:42:49 [6] PPP: ppp1 rcvd [CHAP Success id=0x1 "CHAP authentication success"] 00 50 04 00 00 e5 c7 00 00 6f 72 3
2019-06-22 06:42:49 [6] PPP: ppp1 sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0
2019-06-22 06:42:49 [6] PPP: ppp1 rcvd [IPCP ConfReq id=0x2b <addr 172.16.16.49>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0
2019-06-22 06:42:49 [6] PPP: ppp1 sent [IPCP ConfAck id=0x2b <addr 172.16.16.49>]
2019-06-22 06:42:49 [6] PPP: ppp1 rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2019-06-22 06:42:49 [6] PPP: ppp1 sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
2019-06-22 06:42:49 [6] PPP: ppp1 rcvd [IPCP ConfNak id=0x2 <addr 146.90.58.38> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>]
2019-06-22 06:42:49 [6] PPP: ppp1 sent [IPCP ConfReq id=0x3 <addr 146.90.58.38> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>]
2019-06-22 06:42:49 [6] PPP: ppp1 rcvd [IPCP ConfAck id=0x3 <addr 146.90.58.38> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>]
2019-06-22 07:11:12 [5] System: LAN4 link up 100 mbps
2019-06-22 07:11:36 [5] System: LAN4 link down
2019-06-22 07:11:39 [5] System: LAN4 link up 1000 mbps
2019-06-22 07:11:44 [5] DHCPD: Recv REQUEST from 60:A4:4C:64:12:E7
2019-06-22 07:11:44 [5] DHCPD: Send ACK to 192.168.1.115
2019-06-22 07:12:35 [5] DHCPD: Recv REQUEST from 00:23:24:14:FA:0A
2019-06-22 07:12:35 [5] DHCPD: Send ACK to 192.168.1.108
2019-06-22 07:15:12 [5] DHCPD: Recv REQUEST from 3C:5C:C4:D8:8F:58
2019-06-22 07:15:12 [5] DHCPD: Send ACK to 192.168.1.106
Moderators Note: Personal information removed
22-06-2019 8:59 AM
As I noted, I recall TP routers doing this ... you might want to ask TP support why.
It wound have been useful to know why xDSL went down this morning. It would be worth while looking to see if router stats (link below) works with your router and set up xDSL stats monitoring.
I also observe quite a few issues being reported on LAN1.
26-06-2019 1:12 PM
Thank you Plusnet for the support. I have the white Plusnet router that has arrived in the mail installed in the BT master socket with the microfilter.
Just before I switched out the TP-link VR2800 for the Plusnet one, I did check the log and saw that the router had been up for 4 days and 5 hours, so maybe something has been fixed or maybe me being optimistic.
As advised by email, I am posting here to let you know the Plusnet router is now online.
26-06-2019 1:50 PM
Hello @Slay,
Looking at your connection it definitely seems better, other than one drop this morning it has been stable for the last 3 days. I would advise to keep a close eye on it and get back to us if the drops reoccur and we will investigate this further for you.
26-06-2019 1:56 PM
Thanks, will the speed restriction on the line be reset now?
26-06-2019 3:17 PM
I have made some remote changes to the settings on your line which has increased your speed, which you should notice the difference within the next 4 hours. Get back to us if anything changes.
26-06-2019 4:41 PM
Thanks SammyM. The speed seems much improved. I am away next week, so I intend to leave the Plusnet modem in the master socket for the next 10 days. If my connection is stable, am I OK to replace the adsl faceplate on my BT socket and keep using the Plusnet modem, and following that remaining stable for the week switching back to my own modem?
26-06-2019 5:04 PM - edited 26-06-2019 5:06 PM
I can not see a problem with that @Slay.
Doing it in stages will help rule out each step as a cause.
Let me know how it goes and I hope you enjoy your time away
01-07-2019 9:47 AM
So I've had three disconnects so far. One on the 26/6 at about 7:10PM, one on the 28/6 at about 2.00 PM and one on the 30/6 at about 8PM.
01-07-2019 12:59 PM
Hi Dean,
Thank you for letting us know how you're getting on, I'm sorry for any inconvenience that the connection issues have caused you.
It sounds like things have settled down at the moment, the current level of drops is within the expected range. We consider anything up to three drops in 24 hours or six drops in 72 hours to be normal broadband behaviour. Please let us know if the drops become more frequent than this or if you experience any other problems with your connection.
Regards,
Emily
