Can I request a mod to post my line stats, disconnections
BigTabs
As topic says i would be grateful Thank you
Kind Regards Kyle
12 REPLIES 12
Oldjim
Resting Legend
Fixes: 63
Re: Can I request a mod to post my line stats, disconnections
Moderators are just customers without access to any of the Plusnet systems
BigTabs
Sorry my bad
how can i get my stats
Oldjim
Resting Legend
Fixes: 63
What do you want to know - you can get the sync speed from the BT speedtest by going to further diagnostics and multiply the IP profile by 1.033
BigTabs
I wanted to see my disconnections
Oldjim
Resting Legend
Fixes: 63
Have you looked at the router log - this will show the PPP losses
BigTabs
Due to being on FTTC/FIBRE i did not think it would show
Oldjim
Resting Legend
Fixes: 63
yes it would- it wouldn't show a resync directly but would show a PPP drop which, in most cases reflects a drop in sync although you could get a PPP drop without a drop in sync
BigTabs
Just checked its not showing any disconnections
Oldjim
Resting Legend
Fixes: 63
there is your answer then - you probably haven't had any sync drops
leader
Unfortunately the best way to line stats on fftc is to get hold of an unlocked  bt openreach eci or hg612 modem off ebay* *(other aution sites are available) Smiley
adamwalker
Fixes: 221
These are your connection logs for the past few days:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13668754977209.png"/>
I'm not sure what line stats you might be looking for, do you suspect/have you noticed a particular problem?
Adam
 Adam Walker
Oldjim
Resting Legend
Fixes: 63
Why don't you use your hacked modem to get the results
