Can I migrate to the 21CN connection?
Dazzer
Hi
My exchange (Swainsthorpe) has finally been 21CN enabled and I was wondering if I could be transferred to it?
BT broadband checker now says I should be able to receive approx 15Mb connection. My line attenuation is 15db and noise margin around 6db so I am hoping for a good increase from my current sync rate of 8,128.
Fixes: 145
Re: Can I migrate to the 21CN connection?
One of the Digital Care team hopefully will pick this up tomorrow and place the order for you.
Kitz suggests you could get a good speed http://www.kitz.co.uk/adsl/max_speed_calc.php.
Customer and Forum Moderator. Windows 10 Firefox 62.0.3 (64-bit)
Fixes: 10
Make sure you ask to be put straight on to uncapped upload.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Order placed (with uncapped upstream Smiley ) - it'll complete on the 6th.
Dazzer
Thanks for the replies guys.
That's Service for you!!
Dazzer
EDIT - Ignore this, just read another post about Annex M and I don't want to sacrifice download speed or pay extra for Annex M.
Hi
Just one other thing, I have noticed there are two options for WBC on the BT checker :-  ADSL 2+ and ADSL 2+ Annex M
Reading the PN help files I see Annex M can be requested.  As migration has already been ordered via this thread (thanks Matt) will it be the Annex M flavour?
Is Annex M worth having?
