Can I improve signal strength?
- Can I improve signal strength?
- « Previous
- 1
- 2
- Next »
Re: Can I improve signal strength?
06-12-2012 4:14 PM
I've gone through the various steps but cannot get it to my Plusnet password.
Presumably the Plusnet password I should be using is the one I log into this site with for instance? I have also tried my password with and without adding @plusdsl.net and it still doesn't connect. From memory, I think the light glows yellow, but I'll check tonite.
Am I missing something with my password? Attached is an image of the BT Hub screen with my attempted user/passwords
I also read elsewhere that it is best to set the time/date to manual, I've done this but it doesn't make any difference.
I'll try the suggested 'test' passwords and see how I get on.
Many thanks, Marc
06-12-2012 4:27 PM
The credentials a router needs to connect you to the internet are your User Name followed by @plusdsl.net (no spaces) and your Password.
On the basis of your screen shot, your user name is marcadams (and the password is not shown). If you go to the main Plusnet web site (not this forum web site) you should be able to log in as marcadams and using the same password.
06-12-2012 4:34 PM
06-12-2012 4:46 PM
I use the same password for both the Member Centre and this forum - I'm a creature of habit when it comes to passwords!
I'll give everything another go tonight,
Marc
06-12-2012 4:56 PM
06-12-2012 4:57 PM
Can I recommend http://keepass.info/ With that you can have different passwords for everything and only have to remember the one to get in to KeePass itself.
07-12-2012 8:55 AM
I finally cracked it last evening.
The user and passwords were all correct, the problem seemed to be the date/time. I changed it to manual again and all now works.
I did previously change the time settings but I don't think I saved them so the time etc reverted back to Auto.
I now have a much better signal and range now that I am using the HH3 again as opposed to the Plusnet router.
Re my password, they are consistent for Plusnet but are not the same as I use for other uses etc (ie email, shopping and banking etc). I will however check out keepass as it sounds pretty useful.
Once again, many thanks to you all for your helpful advice.
Regards,
Marc
07-12-2012 9:46 AM
07-12-2012 10:22 AM
- « Previous
- 1
- 2
- Next »
