Can I have two routers on the same Plusnet line ?
- Re: Can I have two routers on the same Plusnet lin...
01-02-2013 11:27 AM
Separate cables in the property.
My main Plusnet router, I use Wi-fi, as it is in a different room to my main Computer room / Study.
Runs two iMacs via Wi-fi at the same time, no problem.
It also has Ethernet connections for SKY+HD On Demand, plus Freeview HD so cannot move that one.
As a hangover from SKY Multi-room, I have a separate discreet phone line in another room.
If I wish to use an older PC with no wi-fi, or SKY+HD On Demand, in that room, with an ADSL filter, can I use a second Ethernet cabled router, at the same time as the Main Plusnet Router, or not at the same time ?
Are there implications for accessing Plusnet with the second router, or is it just a case of setting it up as if it was the only router ?
Plus, an extra phone into the phone circuit.
A non powered phone for power cuts. REN of 1. (Just BT line powered)
(Keeping below the total REN allowance of 4)
TIA
Re: Can I have two routers on the same Plusnet line ?
01-02-2013 11:28 AM
Why not just move the normal router to the other room
01-02-2013 11:41 AM
Quote from: PlusComUK As a hangover from SKY Multi-room, I have a separate discreet phone line in another room.
Do you mean:
1. an extension to your main line? or..
2. a separate line with a different number that you pay rental for separately?
1. No.
2. Yes if you pay for broadband on it.
01-02-2013 1:28 PM
Quote from: Oldjim You can't connect two routers to the phone line
The main router has Ethernet connections for SKY+HD On Demand, plus Freeview HD so cannot move that one.
(Added at the same time as your post, not aware of your post, thanks !!)
@HP Sauce, thanks. Same line, so a No-No.
01-02-2013 1:31 PM
01-02-2013 2:08 PM
In reality, it's just going to be used for a non powered emergency phone, but I thought I'd explore running a second router.
01-02-2013 9:45 PM
I can't for the life of think why you would want to do it though. It would be easier to get a switch as the others have said.
01-02-2013 9:55 PM
01-02-2013 10:02 PM
And this is one solution, having read all of the above...
http://help.sky.com/tv/on-demand/set-up-on-demand-with-a-wireless-connection
http://www.sky.com/products/kit/wireless-connector/index.html
Alternative option, HomePlugs as above, if they support HD Video Downloading or Streaming.
And would also allow PC / iMac connection.
These have good feedback too...
http://www.amazon.co.uk/TP-Link-TL-PA211KIT-200Mbps-Powerline-Ethernet/dp/B004INVKP4/ref=reg_hu-rd_a...
http://www.amazon.co.uk/TP-Link-PA411KIT-AV500-Powerline-Adapter/dp/B0084Y9N3O/ref=dp_ob_title_ce
With a speed of up to 500Mbps, TL-PA411 transmits HD streams, making it a great choice for an easy to build multimedia entertainment network.
@Estragon, thanks for the suggestion.
01-02-2013 10:21 PM
I just gave an example of the technology. They just provide ethernet over the mains wiring.
Quote from: PlusComUK Alternative option, HomePlugs as above, if they support HD Video Downloading or Streaming.
http://www.amazon.co.uk/TP-Link-TL-PA211KIT-200Mbps-Powerline-Ethernet/dp/B004INVKP4/ref=reg_hu-rd_add_1_dp
The speed you need largely depends on your broadband throughput speed. Higher up the ADSL2+ speed range 200Mbps ones can be necessary. Well up the FTTC range they need to be 500Mbps. If you have fairly slow ADSLx then 85s may be enough.
