Can I have a SNR reset please
steve_arnold
Could I have a SNR reset please, so far this year router has reported 50 drops (some were caused by a faulty power grid locally) but router has usually reconnected at around the previous 9-11mb which I'm happy with but on the 16th it droped to around 4 and hasn't come back up. Router log and stats below.
Thanks in advance
Steve
Router log:
Date
Time
Messages
24/01/2020
18:02:59
Received valid IP address from server. Connection UP.
Manual disconnect from router interface
16/01/2020
17:59:39
Line 0: ADSL link up, Bearer 0, us=539, ds=3995
16/01/2020
17:58:37
Line 0: ADSL link up, Bearer 0, us=1087, ds=6807
16/01/2020
17:56:50
Line 0: ADSL link up, Bearer 0, us=1112, ds=9143
16/01/2020
17:12:50
Line 0: ADSL link up, Bearer 0, us=1103, ds=10895
16/01/2020
13:03:56
Line 0: ADSL link up, Bearer 0, us=1112, ds=10332
16/01/2020
12:46:19
Line 0: ADSL link up, Bearer 0, us=1107, ds=10451
16/01/2020
09:38:44
Line 0: ADSL link up, Bearer 0, us=1107, ds=10543
Current router stats:
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 20.4 13.6
Attenuation (dB) 37.5 26.0
Output Power (dBm) 0.0 10.4
Attainable Rate (Kbps) 8208 944
Rate (Kbps) 3995 539
3 REPLIES 3
Fixes: 1,600
Re: Can I have a SNR reset please
Hi Steve
I've just put through an SNR reset now, you should hopefully see an increase within the next 4 hours although you may need to reboot your router after that time. Let us know how you get on Smiley
steve_arnold
Thank you, nothing altered till I rebooted the router this morning, now I have:
  Downstream Upstream
SNR Margin (dB) 6.1 5.7
Attenuation (dB) 40.5 25.8
Output Power (dBm) 0.0 12.6
Attainable Rate (Kbps) 10624 1120
Rate (Kbps) 10575 1127
Fixes: 1,600
No problem, that's looking a lot better!
Let us know if there's anything else you'd need help with
