Can I have 21CN?
Sami1
Can I have 21CN?
Hey all,
Bit of a noobie here with 20CN/21CN stuff. Just wanted to know if I can be ''upgraded'' to the 21CN network. Should be available for my region (Worcester). I just want faster upload speed so I can put bigger stuff on Cloud etc. faster. Is it free?  Smiley
Thank you.
Sami
Re: Can I have 21CN?
Put your phone number in the Sam Knows checker to see what is available at your exchange.
Price is the same for ADSL 20CN, and ADSL2+ 21CN.
Fixes: 9
Better to use http://www.dslchecker.bt.com/adsl/adslchecker.welcome as this will also give a prediction of the speeds you are likely to get. You are looking for WBC ADSL 2+. If it is available make sure you ask for it to be uncapped to get the faster upload.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Sami1
Everything is available from FTTC Range A to Copper Multicast and there WBC ADSL2+. But who do I contact to get that uncapped ADSL2+ working for me? All I have seen on the forum so far is that people post asking abut it and at some point a member of staff writes that he/she has put that on their account.
Fixes: 9
Could you post the full stats from your router please. If you are using a Plusnet supplied router this link should take you to the correct place: http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0
Plusnet Staff
Plusnet Staff
Fixes: 159
You're already on 21CN, as can be seen by your speeds being higher than 8Mb/s. I'm going to place an order to uncap your upstream, this should complete tomorrow.
 Chris Parr
 Plusnet Staff
