Can I get my upload uncapped
Carolgeorge22
Hi plusnet would I be able to get my upload speed un capped please.
1 REPLY
Fixes: 167
Re: Can I get my upload uncapped
Unfortunately your exchange is only 20CN enabled. This means that we'd need to charge £7.83 per month to increase your upload speed, this should increase it from 448kbps to 832kbps. If you want to go ahead with this you can go through trials.plus.net and follow the links for 'Max Premium',
 Chris Parr
 Plusnet Staff
