Can I get my ADSL Upload Uncapped?
spezzer
hi - i've been struggling to upload to iCloud and Facetime is kinda painful so checked out speedtest. Download is awesome 11.85Mbps - Upload is pants! 0.23Mbps  Undecided Can I get this uncapped?
thanks
Grin
Stats...........
Link Information
Uptime: 45 days, 19:58:01
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 13,783
Data Transferred (Sent/Received) [GB/GB]: 16.67 / 194.14
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 13.6 / 24.5
SN Margin (Up/Down) [dB]: 30.0 / 6.7
Loss of Link (Remote): -
Error Seconds (Local/Remote): 352,695 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 83 / 2,776,190
HEC Errors (Up/Down): 37 / 15,907,133
Fixes: 62
Re: Can I get my ADSL Upload Uncapped?
that is bad even for a capped line - can you post the router stats as requested here http://community.plus.net/forum/index.php/topic,96155.0.html
Fixes: 167
The upstream is showing as capped. I'll go place an order to remove the cap, the order should complete on Tuesday.
 Chris Parr
 Plusnet Staff
spezzer
nice one - look forward to it
and thanks for repsonding so quickly
Smiley
Fixes: 62
From the stats - no obvious reason for the rubbish upload in the test
Let's see what happens after it is uncapped
spezzer
thanks - appreciate it
spezzer
Hi - upload speed seems to have improved - i'm getting 1.00Mbps - havent tested iCloud/Facetime yet but theoretically should be 5 times faster! Is this about right for uncapped?
cheers
New stats...
Uptime: 4 days, 9:50:18
Bandwidth (Up/Down) [kbps/kbps]: 1,259 / 14,790
Data Transferred (Sent/Received) [GB/GB]: 26.59 / 225.99
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 13.5 / 25.0
SN Margin (Up/Down) [dB]: 5.8 / 5.1
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 391,812 / 0
CRC Errors (Up/Down): 40 / 99,849
HEC Errors (Up/Down): 26 / 317,551
Joshc
Hey,
On ADSL your never going to get higher than 1.00Mbps.
Unless  annex m is available on a business line only.
So it looks like the uncap order completed.
Smiley
spezzer
okay nice one - thanks for confirming
Smiley
