Can I get a breakdown of BB Usage for a particular date?
- Can I get a breakdown of BB Usage for a particular...
25-11-2012 5:33 PM
-Dave
You know what a turtle is? Same thing.
Re: Can I get a breakdown of BB Usage for a particular date?
25-11-2012 5:54 PM
You set it up, and off it goes..........
It's like the Energizer Bunny, it keeps on going.... until it stops !
25-11-2012 5:56 PM
25-11-2012 6:15 PM
25-11-2012 6:28 PM
25-11-2012 7:53 PM
25-11-2012 8:52 PM
A detailed list from PN will probably tell me the culprit. Especially if the port is 5525, which the savvy among us may recognise as a port used by VUZE.
25-11-2012 9:22 PM
25-11-2012 11:17 PM
So how do you know what type of traffic it is? I assumed it was by particular ports. Or is it by packet inspection?
26-11-2012 12:33 AM
I think accounting is based on the total usage figures supplied by BT. I imagine it is that latter (total usage) data that Plusnet record in hourly slots and can provide for a particular day. Only the total is available, no breakdown by type.
26-11-2012 11:54 AM
As previously mentioned we don't use the router's built-in wifi, and the wireless extender is tied down to Mac address, but even then I'd see IP addresses being assigned in the router's logs.
Can anyone think of a possible explanation for this?
26-11-2012 1:44 PM
26-11-2012 3:15 PM
We have checked and can verify that the only connections that have been online, gone from your single line (one example of this occurring, is the sale of a router but not deleting your credentials from it).
We collect usage information using two mechanisms. One is recorded through information supplied to us at the network edge (as we attach to the BT network) and the other is collected by our traffic management. There is always a difference in the figures for two reasons, 1 the way they are measured is slightly different, 2 the traffic management switches record dropped packets (because the traffic management sees the data and it gets dropped in another portion of the network).
However, the difference between the two values should differ only by a small margin.
I have attached the raw data collected for the 23rd to your ticket. Some explanation of which is which is in the ticket.
Given the two unique measurement points and methods, the data is well within the tolerances expected and would suggest it is correct.
I have highlighted a couple of things about the data, which would suggest the source of it (or will have when I hit send)
27-11-2012 9:01 AM
Source: amdkmdag
Event ID: 62464
Task Category: DVD_OV
It appears this event occurs whenever "windowed video media" is being viewed. My son is on a bit of an Anime kick at the moment, and it turns out he was watching it from 4:25am on Friday when he had an Inset Day. He has had a stern talking to about a) spending so much time on the laptop when he's supposed to be asleep and b) lying about it! Unfortunately he's currently taking steroids as part of his chemo so his sleep patterns are all screwed up, but still...
Just goes to show that no matter how much you trust your kids, they will still lie.
Now I just need to track down the 27Gb that occurred later in the day...when no-one was in!
