Can I change to static IP with Plusnet Unlimited Fibre Extra?
strathbungo
I'm looking to change to a static IP address if possible, same as my server assigned one just now. Remote working, and if electricity drops I'll lose connection to work server...
Can't find the add-on button in my account... is this possible with Fibre Extra broadband?
1 REPLY 1
Fixes: 367
Re: Can I change to static IP with Plusnet Unlimited Fibre Extra?
@strathbungo
It is possible but it will be a different IP address as the static ones come from a different pool. Because of the current situation it might take a while, in the meantime the dynamic addresses these days are quite 'sticky'.
