Can I change Modems
Stanman24
Can I change Modems
I was supplied with an ECI Modem but I want a HG612 instead
is it possible you can swop it over for me ?
Fixes: 247
Re: Can I change Modems
I have an ECI too, and was told by the OR engineer it's better keep them modems matched to the equipment in the cab.
It's owned by OR so I doubt you'll get PN to replace it.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 4
There are five HG612 currently on eBay for £20 or less  Wink
