Can I Turn Router off for 2 weeks?
englishrick
I'm going on hols soon, and wanted to know would it be ok to turn the router off (leaving modem on) as the Asus router I have has blue lights all over the place and I don't want it attracting people to open curtains at night?? thanks
9 REPLIES 9
jelv
Fixes: 10
Re: Can I Turn Router off for 2 weeks?
Not a problem - I'd suggest turning the modem off as well.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
englishrick
Quote from: jelv
I always thought it was best to leave Modem on...
jelv
Fixes: 10
That's true normally, but for an extended period it shouldn't cause any issues.
adamwalker
Fixes: 223
Just to add, it's turning the modem (or router depending on the type of connection) off and on repeatedly, rather than leaving it powered off for an extended period that could cause the speed profile to decrease.
 Adam Walker
valart
I have just come back from my holiday after two weeks switched my router back on and there was no problems in less than no time I was back on line if anything my speeds are up for some reason.
colintivy
That must have been a relief !  My Snr went down the drain after 3hrs off for main supply maintenance by the power company. Not back after a week back on!
Angry Roll_eyes
Cagney1994
Quote from: jelv
I thought the router was the modem ?  Huh
jelv
Fixes: 10
Not on FTTC - you have a separate modem (BT supplied) and router (PN supplied).
Cagney1994
Thanks jelv Smiley
