Cables for fibre
- Re: Cables for fibre
Cables for fibre
24-03-2013 10:05 PM
Hi guys, I’m hopefully moving to the ultimate fibre package early next month, and I wanted to get organised with cables, currently I have white ones and I want order black ones to keep with the rest of my set up. I just wanted to check, what sort of cable I would need to buy for the router to the PC, that’s the only one that’s visible. I know its Ethernet however if there a special type or name or version I should get, thanks for any help.
Message 1 of 5
(877 Views)
4 REPLIES 4
24-03-2013 10:14 PM
Shouldnt need any special ethernet wire. Should be CAT5 or CAT5e. Usually should of got a pair with your router but any cheap cable is fine.
Message 2 of 5
(472 Views)
24-03-2013 10:16 PM
You only get 80Mbits on fibre (if you are lucky) and the LAN ports on your Plusnet router are only rated at 100Mbits.
Message 3 of 5
(472 Views)
24-03-2013 10:22 PM
Quote from: vilefoxdemonofdoom You only get 80Mbits on fibre (if you are lucky)
You can actually get up to 330/30Mbit with fibre if you're really lucky.
Message 4 of 5
(472 Views)
24-03-2013 10:31 PM
I only get 12M up / 62M down.
Message 5 of 5
(472 Views)
