Cabinet
danger11
Cabinet
Hi
Basically my cabinet isnt upgraded for FTTC yet. however at the end of the road there is another cab and FTTC is enabled there, can i request to be moved to this cabinet instead of my current one?
Fixes: 62
Re: Cabinet
Basically - NO  Sad
danger11
Re: Cabinet
what would be the chance of my cabinet being upgraded? will it be upgraded soon? since the cab down the road is active
dannystokie
Re: Cabinet
if you check the BT wholesale checker, it may give you a date
https://www.btwholesale.com/includes/adsl/main.html
other than that, you'd have to email BT Openreach.
