CWMP Timeout?
All Star
Fixes: 6
CWMP Timeout?
As the title, I got this strange entry in my router logs last night. Anyone enlighten me - is the router failing?
If so, I do have a spare 582N I can swap.
Fixes: 21
Re: CWMP Timeout?
Not a sign of a failing router. When your connection restarted it was probably trying to contact the ACS (automatic configuration servers) and probably didn't succeed. Plusnet have had some recent issues with them and this might be some after effect. See http://usertools.plus.net/status/archive/1444384145.htm
If your connection & speed is otherwise OK (leaving your line issue aside) I wouldn't worry. Post back if things become different.
All Star
Fixes: 6
Re: CWMP Timeout?
Thanks AO - I'll leave things alone then.
The line issue will have to wait - still having real-world issues that take priority.
