CONSTANT Packet loss
- CONSTANT Packet loss
31-01-2013 9:42 AM
I was checking the other thread with everyone else's ping graphs and none of them are like mine with the packet loss.
could this be affecting my online gaming too?
my MTU value is 1492 as that is the highest before it gets fragmented.
im on unlimited 21c ADSL with the Pro add on (well so they say)
im on gateway known as ptn-ag04 at the mo but was like that on different gateways too.
Thx
Re: Packet loss
31-01-2013 11:36 AM
Re: Packet loss
31-01-2013 1:40 PM
Re: Packet loss
31-01-2013 1:59 PM
Do you notice any problems with your connection or is it just in the graphs?
Re: Packet loss
31-01-2013 2:08 PM
Re: Packet loss
31-01-2013 2:17 PM
Just to check though - when gaming are you using your connection for other things like torrents at the same time? As this will also cause lag.
Re: Packet loss
31-01-2013 2:32 PM
Re: Packet loss
01-02-2013 1:07 PM
Re: CONSTANT Packet loss
01-02-2013 3:26 PM
01-02-2013 4:09 PM
Just checked and while Interleaving has been set to Auto since the line was provided it's still showing as being on Fastpath (at least, as of the latest update which was yesterday). Is the router reporting that it's now on? We can turn it off if you like, but bear in mind if the line is at all unstable it'll likely get worse without interleaving being on. Please let us know.
01-02-2013 4:38 PM
01-02-2013 5:39 PM
I will keep it like this for now and get back to you if it has made my gaming better or worse, cause when It was on fastpath and it was performing well it was amazing but sometimes It was getting delays which im guessing all them red lines was losing packets
03-02-2013 7:02 PM
03-02-2013 8:48 PM
03-02-2013 9:06 PM
