CN2,increased speeds
Teds31
I have been informed that I will be swiched to CN2 soon, how do I tell when this has  happened ,my speed as recently increased after a bad period of slow speeds ,is there any way in which I can help to keep the new increased speeds. Ted.
Re: CN2,increased speeds
If you have recived an email from Plusnet about this surely it says:
Please note: you may receive messages advising on the progress of your order over the next 5 weeks
Teds31
That should have been 21CN,and yes I did get the E-mail ,but I just wondered if there was a way showing wheather yopu are on 21CN. Ted
Mand
Your order is not complete yet, it's due for Jan 15th.
Teds31
Thank you Mand. Ted
Plusnet Staff
Plusnet Staff
For anyone else wondering what the date will be, about 2 weeks before the order is due to complete a ticket will get created on your account with the activation date. If the ticket isn't there yet then it will be more than 2 weeks in advance or for some reason there was a problem with the order and it was rejected, in which case nothing will change on your connection.
