CM Ticket Pool?
- CM Ticket Pool?
CM Ticket Pool?
10-05-2013 7:58 PM
Alex
Re: CM Ticket Pool?
11-05-2013 7:25 PM
I'm not 100% sure from the top of my head. Did you send a ticket in and get a response from that pool?
Re: CM Ticket Pool?
11-05-2013 7:29 PM
Alex
Re: CM Ticket Pool?
11-05-2013 7:32 PM
Re: CM Ticket Pool?
11-05-2013 7:52 PM
CM stands for Case Management.
You might see the odd one or two of these as we have a number of guys trialling Case Management. This means you should deal with the same person from raising the fault all the way to resolution
Re: CM Ticket Pool?
11-05-2013 7:54 PM
If it means that less time will be wasted because the person you are dealing with already knows what is happening with your individual fault instead of starting from scratch every time someone replies to the ticket that will be great!
Alex
Re: CM Ticket Pool?
11-05-2013 7:56 PM
It's working pretty well so far and I think it will certainly help the Customer's Experience.
Re: CM Ticket Pool?
11-05-2013 7:58 PM
Is the plan to roll this out fully and when a customer creates a new ticket it is automatically assigned to a Faults Agent (with say the lowest ticket count) and then that person will deal with it?
Re: CM Ticket Pool?
11-05-2013 8:00 PM
Re: CM Ticket Pool?
11-05-2013 8:23 PM
Re: CM Ticket Pool?
11-05-2013 8:24 PM
Re: CM Ticket Pool?
11-05-2013 8:26 PM
