CLOSED / ANSWERED What is my Wireless Router type G or N
- CLOSED / ANSWERED What is my Wireless Router type ...
21-12-2012 2:25 PM
Hello,
I am looking to purchase a Wireless Network Adapter for my desktop and I would like to confirm whether my router at home is a G or an N.
It is a 'technicolor' white colour TG582n
Thank You
Thank You
Message 1 of 5
(1,064 Views)
4 REPLIES 4
Re: What is my Wireless Router type G or N
21-12-2012 2:37 PM
That's a wireless N router, with speeds up to 150Mb/s. Hope that helps.
Message 2 of 5
(485 Views)
21-12-2012 2:41 PM
Awesome! Thank You very much!
Message 3 of 5
(485 Views)
21-12-2012 2:59 PM
I always get a bit confused by wireless-n because it seems to incorporate a wide range of possibilities. It can work at 2.4GHz (as per wireless g) but also 5 GHz. This means a router can run two wireless networks simultaneously or, possibly, increase the throughput by using a channel at each frequency simultaneously.
I think the TG582n only operates at 2.4GHz which means it can only go up to 150Mb/s wireless. So it's wireless n basic, if you like, and any cheap wireless n adaptor should be suitable.
Message 4 of 5
(485 Views)
Re: CLOSED / ANSWERED What is my Wireless Router type G or N
21-12-2012 6:32 PM
Up to 130Mb/s actually.
And no, not any really cheap single antenna N150 adapter would be suitable, because that would only do 65Mb/s on a single width 20MHz channel. A N300 or better adapter would be more appropriate.
Message 5 of 5
(485 Views)
