Business Broadband Speed vs Mobile Connection
ChrisM3
Hi all
I have a conundrum which I am interested to hear peoples thoughts on along with any PlusNet staff thoughts
We have a business broadband connection which has run for just over 12 months, so 12 months left to run
When we ordered the broadband from PlusNet the indicated min speed was - Minimum Guaranteed Speed: 13.7Mb
Very soon after the connection was completed this speed was modified to - 7.9mbs (yes its true in this day and age!). I made a big fuss and asked for Open Reach to visit but unfortunately got nowhere. While upset we were told that it could only get better and to wait and see.
Well we have waited for 12 months and the speed is still as bad
Now here is what I have discovered - I have been testing speeds using a mobile wifi router and the speed is a whole lot better than the landline connection. I have tested using EE and O2 so have a choice. Unfortunately Virgin fibre does not serve the area we are in. Unlimited data cost is £21 over the year with Lyca (O2) or £24.50 month over two years with EE, BOTH these prices are less than we are currently paying for the Plusnet landline connection which is almost unusable!
My question is two fold -
Bearing in mind that PlusNet are pulling out of the Business broadband supply and that although we have tried to stick with the service in the hope it improves, it is still lower than we were told when placing the order. Would we have a case for cancelling?
Or do PlusNet run a sim only unlimited data service which we could move to (probably unlikely but worth asking)
I am interested in hearing thoughts
15 REPLIES 15
Legend
Fixes: 290
Re: Business Broadband Speed vs Mobile Connection
What are your actual speeds over the PN connection, which product are you signed up to, and what does https://www.broadbandchecker.btwholesale.com/#/ADSL show? A screenshot of the result, obscuring your phone number is needed.
ChrisM3
Unfortunately I am not at the business at the moment so cannot look at the router for current speed. But in our Plusnet account is says -
  • Product:  Unlimited Business Fibre Broadband and phone (Contracted)
  • Estimated Download Range:  8 - 9Mbps
  • Estimated Upload Range:  0.4 - 0.5Mbps
  • Minimum Guaranteed Speed:  7.9Mbps
  • Current Line Speed (Download):  9.3Mbps
When placing the order we were told -
At peak times, we estimate that you'll get the following speeds on your line:
Download: 16 - 24Mb
Upload: 2.5 - 4Mb
See attachment as requested
Fixes: 430
@ChrisM3
The bottom line as I understand it is that if your contract states a MGALS of 13.7Mbps then regardless of what you have since been told, if your sync speed is below 13.7Mbps a month after you have reported a speed fault then Plusnet will release you from your contract penalty free.
 It could be that you have a fixable problem that just hasn't been properly addressed. Due to the time that has elapsed then I suggest that you start again, go through the checks suggested by @jab1 to give us better visibility of your issue.
Legend
Fixes: 290
Oh dear, you must be a long way from the Fibre cab - those speeds are terrible, and the last OR test is a little bit old. You may well find a 4G connection gives you slightly higher speeds.
ChrisM3
This is my understanding BUT a week or so after we were connected my account changed from the speeds on the order (and initial speeds in my account) to -
I argued at the time that this was not acceptable and was talked into going with the speeds we had (of course I wish now that I had considered mobile wifi).
ChrisM3
Yes I have been testing 4g and its a whole lot faster but this is the reason for my posting now, I want to find out the chance of either cancelling or moving to 4g with PlusNet (not sure there is an unlimited mobile plan with PlusNet)
Fixes: 430
@ChrisM3
Your last reply crossed with my post. I suggest that you report a fault and if Plusnet tell you again that they cannot supply the MGALS in your contract that you ask to be released from the contract due to Openreach being unable to supply what you ordered. https://www.plus.net/help/report-a-problem/broadband/#broadband
Edit, this is moving very fast, have you got the original email sent to you when you first signed up? There should also be a closed ticket in your account with these details.
ChrisM3
Thanks although at the time I made a big fuss and actually met Open Reach on site who were there for a couple of hours investigating whether anything could be done 😞
ChrisM3
Thanks I will get the fault reporting under way straight away
Thank You
Legend
Fixes: 290
PN do not offer 4G as an option. As @Baldrick1 says, despite what you have been told, the initial contract guarantee hold, and you were advided wrongly.
ChrisM3
Thank you. I have been kicking myself that I did not investigate other options once the speed issue arose, and I let them talk me into staying with the contract.
I will get onto raising a fault again now and see how it runs
Smith7
All Star
I don't understand why more people don't go down the mobile route will be even better when the 5G goes to more places
A friend of mine who moved into a new house with no landline had a mobile Broadband deal with Three where they lived there was a very good Three signal picked up a box from the Three shop all working the same day and he takes it on holiday
When I go on holiday to the caravan I use the hotspot on my phone and cannot tell any difference between the wired connection at home and the mobile broadband I don't play games
USwitch have some very special deals on U/L data and cheap boxes on EBay
Good luck just go for it most are on 30 day deals so you can see/try what you can get
ChrisM3
Yeh I just don't understand why I have not thought of it before. I have been testing with a basic 4g dongle over the last few days and even with just a basic Huwaei dongle the speed is hugely faster than the disaster which is landline.
I just have to get the landline cancelled and have started that process after advice given here today. PlusNet have admitted that I am not getting the guaranteed speed in the initial contract, but they still want Open Reach to try again (despite two attempts in the month after the service was installed). I just plan to let it run its course and then cancel out of contract due to them not supplying the promised speed.
Interestingly monthly cost is almost the same so that's good
Chris
Smith7
All Star
Lebara  ( Vodafone )  do some good U/L data deals with discounts for three months via USwitch with no  stupid price increases every March price increases on top of last years price increase like a snowball getting bigger
I find the Vodafone signal better that EE but depends where you live and the PN is not as good as EE
