Buffering :(
rongtw
Fixes: 12
Buffering :(
I have seen several posts here about gateway problems / slow connections .
I myself have recently have had problems with slow page load times , but now i am having trouble with streaming TV < Channel 4 / BBC i player , keep warning me " insufficient bandwidth "
I have fibre unlimited 80/20  Cool and a netgear WNR 1000v3 supplied from PN
speedtest.net keeps saying my speed is constant , ping test is fine
Broadband Ping
<img src="http://www.speedtest.net/result/3359239093.png" />
[Moderator's note by Adie (dvorak) fixed linky]
Fixes: 247
Re: Buffering :(
I've been streaming BT sport, ITV player and Sky sports without any buffering today
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
shalom2010
Re: Buffering :(
Been watching iPlayer on a SmartTV 40 feet from router (582n) for last 4 months, only one or two buffering issues for a few seconds.
Fixes: 10
Re: Buffering :(
Are you using a wired or wireless connection to the router?
Which exchange are you on?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
rongtw
Fixes: 12
Re: Buffering :(
@Jelv ,,,  Wired ,
Code: MYUND
County: West Yorkshire
Enabled: 10 Sep 2003
Market: 3
Mkt2014: B
Undercliffe exchange
Fixes: 10
Re: Buffering :(
Could you run the thinkbroadband speed test and post the results. http://www.thinkbroadband.com/speedtest.html
The graphs that gives might indicate something.
Does it stream OK at some times of the day?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Buffering :(
Would you also be able to run the BT Speedtester at http://speedtest.btwholesale.com including 'Further Diagnostics' ?
Chris Pettitt
Cloud Environments Engineer
rongtw
Fixes: 12
Re: Buffering :(
bt speedtest done  Wink                  DL 73.2 upload 16.6
My Broadband Ping
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Buffering :(
Are you still getting the error message this morning too?
Chris Pettitt
rongtw
Fixes: 12
Re: Buffering :(
just the odd page slow load , for some reason its worse here  Embarrassed
havent tried Iplayer yet
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Buffering :(
Ok.
Let me know if iPlayer is still causing you problems.
Chris Pettitt
rongtw
Fixes: 12
Re: Buffering :(
channel 4 still saying not enough bandwidth , Iplayer buffering  & keep getting iplayer test error  Embarrassed
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Buffering :(
Can you drop your PPP Session (log into your router hit 'Disconnect' and 'Connect' again) and see if that resolves the issue please?
Chris Pettitt
rongtw
Fixes: 12
Re: Buffering :(
have already  done that several times , and gateway hopped , but will do again  Wink
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Buffering :(
I've made a few back end changes to see if that resolves the issue for you.
Chris Pettitt
