Buffering
valart
Buffering
I was watching the semi finals at Wimbledon yesterday on my laptop and the old buffering circle was doing over time on my screen sometimes I have no problems but yesterday was a waste of time,can someone explain why this happens is it to do how busy it is online.
deathtrap
Re: Buffering
It's a possibility as it will play a part in the scheme of things, could be the CDN that you got connected to getting swapped around to another ,(which should be seamless) could be the peering transit used as well
Fixes: 67
Re: Buffering
We're not aware of anything obvious or any widespread reports of any issues on Saturday. Not that it should have had an impact but I would imagined to see more expected to see any such issues flagged on Sunday rather than Saturday.
Adam
 Adam Walker
Fixes: 5
Re: Buffering
Anyone else experience buffering?
Kelly Dorset
Broadband Service Manager
rongtw
Fixes: 12
Re: Buffering
Kelly ,, yup me too was bad , eventually had pinch remote off the wife  Wink to watch it on TV ,,,, just put it down to loads of connections at same time on PN gateways
Fixes: 5
Re: Buffering
rongtw: Your line profile is currently set too high.  Were you doing anything else at the time?
Kelly Dorset
rongtw
Fixes: 12
Re: Buffering
@Kelly sorry i cant multi task  Wink one thing at a time .
How is my profile set too high  Huh am on 80/20 & getting 72/17
ok its dropped a bit from normal  Shocked
Fixes: 10
Re: Buffering
I think he means that your current line speed on the PN portal is set higher than the IP Profile reported by the BT speed test.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
St3
Aspiring Champion
Fixes: 5
Re: Buffering
hey plusnet guys ive noticed on my mum, brothers accounts it shows 7.5 meg speeds but the max they can get it 2 meg so maybe theres some kinda error in the PN portal
rongtw
Fixes: 12
Re: Buffering
back to normal  Cool
Grezzer36
Re: Buffering
Quote from: ukste20
My PN profile shows same problem. Shows current line speed as 7.15mb, it's never higher than 2.0 - 2.3mb. Router shows current connection as 2.592mb which is as high as it gets.
Obviously something wrong with PN stats.
Fixes: 67
Re: Buffering
Hi all,
@rongtw
Yes, your profile looks fine now.
@ukste20
Mind PMing their usernames over please so I can do some digging?
@Grezzer36
In your case the IP profile at BT's side had lowered, I've submitted an SNR reset which should see that right within a couple of hours. I'll check the BT IP profile later today and make sure the profile on our side matches.
 Adam Walker
Grezzer36
Re: Buffering
Thanks Adam. Will keep an eye on it from my end. Router re connected at your re set at 2.3mb.
Fixes: 67
Re: Buffering
Hi all,
I just wanted to update you that the mismatch between BT's profiles and ours as some of you have notices has already been picked up on and we're dealing with this specific issue on problem 75634
Adam
 Adam Walker
St3
Aspiring Champion
Fixes: 5
Re: Buffering
Cheesy
