Bt speedtest
farnorth
Bt speedtest
Hi
First off I'm very happy at the moment, my line has been stable for about 200 hours now, with a 1mb connection and download speeds of 990kbps. Which is brilliant for up here, weather has been very calm no gales etc.
I have a couple of questions though.
About ten days ago interleaving was switched on on my line, it may be a coincidence but since then the BT speedtest doesn't work. It sits there for a while and comes back with a test error message.
Also on the speed part of the Plusnet portal it used to say: estimated line speed 0.5mb and then whatever speed I was getting at the time.
Now it says: Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
1 Mb.
Are these things linked?
Steve
Seasoned Pro
Re: Bt speedtest
With regard to the BT Speedtest see this thread here...http://community.plus.net/forum/index.php/topic,93646.144.html
If life gives you lemons, make lemonade.
farnorth
Re: Bt speedtest
Thanks for that, water much less muddy!
Re: Bt speedtest
"Not recorded (service activated before we introduced estimates)"
No one wants to give an answer as to why that has changed as the reason given is not valid.
Fixes: 68
Re: Bt speedtest
That message is probably computer speak for "error encountered trying to retrieve your value from the database". In the absence of a precise message for that it shows the one you see. Cry
The proper value will no doubt return when the error is fixed.
David
Re: Bt speedtest
You're probably right, just a passing bug.
