Browsing Through Treacle today
- Browsing Through Treacle today
- « Previous
- 1
- 2
- Next »
Re: Browsing Through Treacle today
04-12-2007 9:02 PM
P.
05-12-2007 12:35 AM
I wonder if the tweak test knows something when it suggests checking for GlobalMaxTcpWindowSize in the registry and if present changing it to -1 (decimal); I'm guessing that probably means infinity in positive-binary. I've never seen that recommendation before. Of course, if you do plan to change the registry do a back-up first.
The MTU on the new NIC is fine (1500). However I think by trying your old NIC you've established the behaviour must be something to do with the new one. Have you tried searching on the Internet using the make and model of the new NIC and perhaps the words slow and start? Note that slow-start is a normal TCP protocol activity (for congestion avoidance) but not to that extreme.
It's unlikely to help with the slow-start problem but I suggest you download DrTCP from the DSLreports site and use it to increase RWIN to 116800.
As far as having two network cards enabled simultaneously, my inclination would be to avoid this; routers obviously do that but their operating system is written specially to support that - Windows probably isn't.
05-12-2007 12:55 AM
That being said though it's still probably best to try and fix what's causing the speed issue than leave it, have you checked the manufacturer's site? There might be updated drivers or if they have a forum other people that have/had the same problem.
Plusnet Technology
05-12-2007 4:29 PM
P.
06-12-2007 8:18 PM
Cheers.
Jon
06-12-2007 8:22 PM
B.
06-12-2007 8:27 PM
06-12-2007 11:31 PM
With two NICs on your computer they must go into different router ports, but have you tried swapping them over? And using different ports?
13-12-2007 8:35 PM
PT
13-12-2007 11:08 PM
- « Previous
- 1
- 2
- Next »
