Broadband usage
ralphmalph
Broadband usage
Hi, I have Broadband installed at my Caravan and have noticed there is usage on days I am not there.
It is minimal, average of around 130kb a day but just wondered if this is normal or should I flag it up?
Fixes: 100
Re: Broadband usage
They're usually just 'keep alive' packets and general house-keeping, nothing to be concerned about.
If the router is left on and has Wifi enabled and the amount of data increases substantially then it becomes more of a concern.
Customer and Forum Moderator.
ralphmalph
Re: Broadband usage
Thanks for that Strat.
Fixes: 65
Re: Broadband usage
Don't worry, that's completely normal. It's just the router sending out packets of information in order to check tat the connection is still up.
 Adam Walker
ralphmalph
Re: Broadband usage
Thanks Adam.
