Broadband throttling?
deemax
Hi, Ive just check my broadband speed and is only 2.2mb/s usually is 14mb/s. does it mean Plusnet slows me down due to 114gb transferred this month? never had any speed problems on my line.
5 REPLIES 5
Fixes: 1,466
Re: Broadband throttling?
Nope, PN don't throttle speed based on usage.
114GB isn't that much to be honest.
deemax
very strange as I never had any problem with my router and line. maybe some works on network?
Aspiring Legend
Fixes: 196
@deemax A speed reduction of that magnitude does seem a bit drastic.Smiley
If you can, maybe having a look at the 'ADSL - speed faults' post near the top of this board might be an idea?
deemax
@jab1 I'll check. Thanks.
Fixes: 1,551
I've tested your line @deemax and can't find a definitive cause of the problem.
Having said that we can see your connection is dropping frequently which is likely causing slow speeds.
I've made a change to the broadband settings on your line which should help.
Can you let us know how things go after about an hour or so?
Anoush
