Broadband terribly slow - troubleshooter not working
- Re: Broadband terribly slow - troubleshooter not w...
07-02-2014 11:57 PM
I have a problem with my broadband speed: according to my router I'm getting an upload speed of 0.448 and a download speed of 8.128 (SNR 12, loop att. 22), but using the internet is terribly slow. According to the BT speed test I'm just getting 2.34 (down) and 0.3 (up) speed, which is much slower than my line speed.
I just moved home, so somehow I have the feeling that the speed profiles of my old and new line are mixed up. Plus.net is still showing my old line speed and diffferent telephone numbers, depending where I'm looking...
Unfortunately the plus.net troubleshooter isn't working (it always lead to an error page: Broadband Troubleshooter - Error, There's been a problem, Please try using the Broadband Troubleshooter again in a short while. If you continue to have problems please contact our Support Team for help).
Can anyone help me here? Unfortunately I cannot find an email address for the plus.net support... and the help assistant is always leading me back to the faulty troubleshooter.
Thanks,
Jan
Thanks,
Jan
Message 1 of 9
(2,192 Views)
8 REPLIES 8
Re: Broadband terribly slow - troubleshooter not working
08-02-2014 12:15 AM
Quote from: cyrix2000 Unfortunately I cannot find an email address for the plus.net support...
That's because there isn't one!
Message 2 of 9
(860 Views)
08-02-2014 1:18 AM
@cyrix2000 - It's probably your Current Line Speed that is the blockage - it should catch up if it's low compared to your BT IP Profile.
Message 3 of 9
(860 Views)
08-02-2014 7:36 AM
The current line speed is 2.5Mb and estimated line speed is 3.5Mb but these values were last updated on the 30st of December on my old telephone line. Now the line is synced at 8Mb but somehow all the profiles haven't been updated (I'm now in my new place for a week, this should have happened by now I guess...)
Message 4 of 9
(860 Views)
08-02-2014 8:03 AM
Hopefully one of the digital care team will pick this up when they see it. They don't always man the forums at the weekend though so please don't feel ignored if you don't get an answer until Monday
Message 5 of 9
(860 Views)
08-02-2014 8:57 AM
Hi cyrix2000
It looks like the profile on our side had not updated yet, I have manually updated this. Could you restart the router and hopefully the speed should be back to normal.
Please reply back to the ticket if you need any further assistance.
Stuart
Stuart
Message 6 of 9
(860 Views)
08-02-2014 9:21 AM
Hi Stuart,
Thanks, the problem is fixed now 🙂
Message 7 of 9
(860 Views)
08-02-2014 9:52 AM
Quote from: spickering Could you restart the router and hopefully the speed should be back to normal.
I despair! That was the wrong advice.
Restarting the router is seen as a loss of sync by the DLM. Picking up the changed current line speed requires restarting the PPP session which is done by doing a disconnect/connect via the router interface. That is done with no loss of sync.
Also has the issue with the change of phone number been sorted? Until it is there will be continuing issues.
Message 8 of 9
(860 Views)
08-02-2014 10:11 AM
Message 9 of 9
(860 Views)
