Broadband stability
- Broadband stability
Broadband stability
Broadband stability
05-11-2012 12:01 PM
Router log
Nov 02 05:15:14 home.gateway:ppp:none: Channel Id(0) disconnected after (13 hr 23 min 17 sec)
Nov 02 05:15:14 home.gateway:im_backend:none: Changed ipwan IP address to 0.0.0.0
Nov 02 05:15:24 home.gateway:loadbalance:none: Use backup WAN [ipwan2]
Nov 02 05:15:39 home.gateway:usb:none: _3Ginit: SIM PIN OK
Nov 02 05:15:41 home.gateway:ppp:none: Channel Id(0) connected
Nov 02 05:15:41 home.gateway:im_backend:none: Changed ipwan IP address to 212.xxx.xxx.xxx
Nov 02 05:15:41 home.gateway:usb:none: USB modem call connected!
Nov 02 05:15:46 home.gateway:ppp:none: Channel Id(1) connected
Nov 02 05:15:49 home.gateway:im_backend:none: Changed ipwan2 IP address to 10.xxx.xxx.xxx
Nov 02 05:16:39 home.gateway:ppp:none: Channel Id(1) disconnected after (0 hr 0 min 54 sec)
Nov 02 05:16:39 home.gateway:im_backend:none: Changed ipwan2 IP address to 0.0.0.0
Nov 02 05:16:49 home.gateway:loadbalance:none: Use main WAN [ipwan]
Nov 02 05:16:51 home.gateway:usb:none: USB modem call disconnected!
Nov 02 22:15:05 home.gateway:ppp:none: Channel Id(0) disconnected after (16 hr 59 min 24 sec)
Nov 02 22:15:05 home.gateway:im_backend:none: Changed ipwan IP address to 0.0.0.0
Nov 02 22:15:22 home.gateway:loadbalance:none: Use backup WAN [ipwan2]
Nov 02 22:15:26 home.gateway:ppp:none: Channel Id(0) connected
Nov 02 22:15:26 home.gateway:im_backend:none: Changed ipwan IP address to 212.xxx.xxx.xxx
Nov 02 22:15:28 home.gateway:usb:none: _3Ginit: SIM PIN OK
Nov 02 22:15:29 home.gateway:usb:none: USB modem call connected!
Nov 02 22:16:45 home.gateway:usb:none: USB modem call disconnected!
Nov 02 22:16:46 home.gateway:loadbalance:none: Use main WAN [ipwan]
Nov 04 01:11:05 home.gateway:turbo_extEvtHandlerProc:none: ADSL line is DOWN!
Nov 04 01:11:15 home.gateway:ppp:none: Channel Id(0) disconnected after (26 hr 55 min 48 sec)
Nov 04 01:11:15 home.gateway:im_backend:none: Changed ipwan IP address to 0.0.0.0
Nov 04 01:11:22 home.gateway:loadbalance:none: Use backup WAN [ipwan2]
Nov 04 01:11:34 home.gateway:usb:none: _3Ginit: SIM PIN OK
Nov 04 01:11:36 home.gateway:usb:none: USB modem call connected!
Nov 04 01:11:40 home.gateway:ppp:none: Channel Id(1) connected
Nov 04 01:12:35 home.gateway:turbo_extEvtHandlerProc:none: ADSL line is UP!
Nov 04 01:12:59 home.gateway:im_backend:none: Changed ipwan2 IP address to 10.xxx.xxx.xxx
Nov 04 01:13:00 home.gateway:ppp:none: Channel Id(0) connected
Nov 04 01:13:05 home.gateway:im_backend:none: Changed ipwan IP address to 212.xxx.xxx.xxx
Nov 04 01:13:22 home.gateway:ppp:none: Channel Id(1) disconnected after (0 hr 1 min 42 sec)
Nov 04 01:13:22 home.gateway:im_backend:none: Changed ipwan2 IP address to 0.0.0.0
Nov 04 01:13:29 home.gateway:loadbalance:none: Use main WAN [ipwan]
Nov 04 01:13:34 home.gateway:usb:none: USB modem call disconnected!
----------- system log buffer tail --------------
Mario
Re: Broadband stability
05-11-2012 2:58 PM
We weren't seeing drops every half hour from our side... there were definitely some drops a few days back, though a bit more random than that. Also they seem to have cleared up now?
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13521274616805.png" />
Please let us know if you're still seeing the same things?
09-11-2012 1:33 PM
Nov 06 19:00:32 home.gateway:ppp:none: Channel Id(0) disconnected after (65 hr 47 min 32 sec)
Nov 06 19:00:32 home.gateway:im_backend:none: Changed ipwan IP address to 0.0.0.0
Nov 06 19:00:50 home.gateway:loadbalance:none: Use backup WAN [ipwan2]
Nov 06 19:00:55 home.gateway:ppp:none: Channel Id(0) connected
Nov 06 19:00:55 home.gateway:im_backend:none: Changed ipwan IP address to 212.159.xxx
Nov 06 19:00:56 home.gateway:usb:none: _3Ginit: SIM PIN OK
Nov 06 19:00:57 home.gateway:usb:none: USB modem call connected!
Nov 06 19:01:01 home.gateway:ppp:none: Channel Id(1) connected
Nov 06 19:01:01 home.gateway:im_backend:none: Changed ipwan2 IP address to 10.29.xxx
Nov 06 19:02:02 home.gateway:ppp:none: Channel Id(1) disconnected after (0 hr 1 min 2 sec)
Nov 06 19:02:02 home.gateway:im_backend:none: Changed ipwan2 IP address to 0.0.0.0
Nov 06 19:02:12 home.gateway:loadbalance:none: Use main WAN [ipwan]
Nov 06 19:02:14 home.gateway:usb:none: USB modem call disconnected!
Nov 07 08:44:19 home.gateway:ppp:none: Channel Id(0) disconnected after (13 hr 43 min 23 sec)
Nov 07 08:44:19 home.gateway:im_backend:none: Changed ipwan IP address to 0.0.0.0
Nov 07 08:44:28 home.gateway:loadbalance:none: Use backup WAN [ipwan2]
Nov 07 08:44:32 home.gateway:ppp:none: Channel Id(0) connected
Nov 07 08:44:32 home.gateway:im_backend:none: Changed ipwan IP address to 212.159.xxx
Nov 07 08:44:34 home.gateway:usb:none: _3Ginit: SIM PIN OK
Nov 07 08:44:35 home.gateway:usb:none: USB modem call connected!
Nov 07 08:44:39 home.gateway:ppp:none: Channel Id(1) connected
Nov 07 08:44:39 home.gateway:im_backend:none: Changed ipwan2 IP address to 10.95.xxx
Nov 07 08:45:42 home.gateway:ppp:none: Channel Id(1) disconnected after (0 hr 1 min 3 sec)
Nov 07 08:45:42 home.gateway:im_backend:none: Changed ipwan2 IP address to 0.0.0.0
Nov 07 08:45:52 home.gateway:loadbalance:none: Use main WAN [ipwan]
Nov 07 08:45:53 home.gateway:usb:none: USB modem call disconnected!
Nov 07 10:24:27 home.gateway:ppp:none: Channel Id(0) disconnected after (1 hr 39 min 53 sec)
Nov 07 10:24:27 home.gateway:im_backend:none: Changed ipwan IP address to 0.0.0.0
Nov 07 10:24:36 home.gateway:loadbalance:none: Use backup WAN [ipwan2]
Nov 07 10:24:42 home.gateway:usb:none: _3Ginit: SIM PIN OK
Nov 07 10:24:43 home.gateway:usb:none: USB modem call connected!
Nov 07 10:24:43 home.gateway:ppp:none: Channel Id(0) connected
Nov 07 10:24:43 home.gateway:im_backend:none: Changed ipwan IP address to 212.159.xxx
Nov 07 10:24:47 home.gateway:ppp:none: Channel Id(1) connected
Nov 07 10:24:47 home.gateway:im_backend:none: Changed ipwan2 IP address to 10.143.xxxx
Nov 07 10:25:49 home.gateway:ppp:none: Channel Id(1) disconnected after (0 hr 1 min 3 sec)
Nov 07 10:25:49 home.gateway:im_backend:none: Changed ipwan2 IP address to 0.0.0.0
Nov 07 10:25:59 home.gateway:loadbalance:none: Use main WAN [ipwan]
Nov 07 10:26:01 home.gateway:usb:none: USB modem call disconnected!
Nov 07 18:26:51 home.gateway:turbo_extEvtHandlerProc:none: ADSL line is DOWN!
Nov 07 18:26:55 home.gateway:ppp:none: Channel Id(0) disconnected after (8 hr 2 min 12 sec)
Nov 07 18:26:55 home.gateway:im_backend:none: Changed ipwan IP address to 0.0.0.0
Nov 07 18:27:04 home.gateway:loadbalance:none: Use backup WAN [ipwan2]
Nov 07 18:27:10 home.gateway:usb:none: _3Ginit: SIM PIN OK
Nov 07 18:27:12 home.gateway:usb:none: USB modem call connected!
Nov 07 18:27:16 home.gateway:ppp:none: Channel Id(1) connected
Nov 07 18:27:16 home.gateway:im_backend:none: Changed ipwan2 IP address to 10.143.xxxx
Nov 07 18:27:33 home.gateway:turbo_extEvtHandlerProc:none: ADSL line is UP!
Nov 07 18:28:05 home.gateway:ppp:none: Channel Id(0) connected
Nov 07 18:28:05 home.gateway:im_backend:none: Changed ipwan IP address to 212.159.xxx
Nov 08 03:11:35 home.gateway:ppp:none: Channel Id(1) disconnected after (8 hr 44 min 20 sec)
Nov 08 03:11:35 home.gateway:im_backend:none: Changed ipwan2 IP address to 0.0.0.0
Nov 08 03:11:45 home.gateway:usb:none: USB modem call disconnected!
Nov 08 03:11:58 home.gateway:loadbalance:none: Use main WAN [ipwan]
Nov 08 03:12:02 home.gateway:usb:none: _3Ginit: SIM PIN OK
I have reported it to customer support at Billion (who are great by the way) to see if they have any ideas too.
If nothing comes of it looks like I will have to get onto BT. Oh goodie!
Thanks for checking
09-11-2012 1:55 PM
09-11-2012 2:18 PM
Quote from: thetool Nov 07 10:24:43 home.gateway:usb:none: USB modem call connected!
What are you using to connect, a router or a USB modem?
Could you post to say whet model it is please.
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
09-11-2012 3:15 PM
Everything seems fine, but you do have low SNR (downstream) reading of 6.5db which might be causing the issue.
Can you ask your ISP to higher your downstream SNR to 9.0db, hopefully this setting should make your ADSL line more stable.
Hope this means something to you. Any Ideas of the best way to ask for this?
Oh its a Billion 7402NX router.
09-11-2012 3:43 PM
09-11-2012 3:43 PM
6db margin should normally be fine (there's plenty running on ADSL2+ with a 3db margin). If there are a lot of disconnects the exchange tries changing things automatically to try to make it more stable and the first thing it does is increase the target SNR to 9db. Whilst we frequently see people on here asking for their noise margin to be decreased so that they get better speeds, it's unusual to see people asking for it to be increased (which will give a slower sync speed).
How often is it disconnecting?
Do the disconnects correspond to use of the phone (incoming or outgoing)? Have you anything except a phone and the router plugged in to a phone socket? Are there filters in all the sockets in use?
12-11-2012 8:44 AM
Looking at the pattern, not that there is one. But it seems to be getting less and less, not even one yesterday. I think I will keep an eye on it for a few more days before I decide what to do.
Thanks everyone.
12-11-2012 12:02 PM
Adam Walker Plusnet Help Team |
