Broadband spped unstable
michael41
Hi
I am having trouble with my broadband sometimes the speed is 1420kbps , but recently its been dropping to 128kbps mostly in the evenings and first thing in the morning.
I am currently on the 60GB bandwidth package so I cant understand why this is happening.
Regards
Michael
31 REPLIES 31
michael41
Re: Broadband spped unstable
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 426504 423003 0 10888 15176 00:54:39
LAN 10M/100M 35485 34132 0 1408 1038 00:55:13
WLAN 11M/54M 397733 402093 0 16833 11876 00:55:05
ADSL Link Downstream Upstream
Connection Speed 2016 kbps 448 kbps
Line Attenuation 59.0 db 30.5 db
Noise Margin 9.4 db 12.0 db
Paulg78
have you got any extensions plugged in, ?
michael41
Hi
I have no extensions plugged in, my son lives a couple of hundred yards away and he's complaining about the same fault he is also on the 60 gb package.
So I am thinking the fault must be on the line.
Regards
Michael
Paulg78
To be honest , with your line attenuation and noise margin, the sync speed is pretty close to what you should be recieving, you could try a few things such as a good quality dsl filter or try another router, as your line is quite long there are a few routers on the market that help with long line speed and stability also you could try and sweet talk someone and ask if you could have your Noise Margin reset back to 6db that could also help , do you suffer many connection dropouts at all ?
michael41
Hi Paul,
I am not suffering from dropouts , but sometimes the internet is that slow I just leave it and when I do a spped check it shows 128kbps,
There doing work on the lines at the minute installing fibre optic cabinets maybe that is causing some problems.
Regards
Michael
Paulg78
Hiya Michael,
To be honest mate ,I would sit tight if they're installing FTTC or FTTH in your street and if you wanted, upgrade or change isp to take advantage of the technology ,  I've got to wait till December 2011 , wish I was in your shoes
chris2005
Hi paul,
I am michaels son and I live less than half a mile away , my internet at this time of night is nearly unusable I have reset the router but its still terrible.
They installed new boxes a few mile away about two months ago I thought it would have been up and running by now.
Heres my router stats and speed test results.
System Up Time 01:30:14
WAN PPPoA 15814 17396 0 481 1573 01:27:09
LAN 10M/100M 12020 10792 0 1004 270 01:30:10
WLAN 11M/54M 5451 5906 0 579 249 01:30:00
Connection Speed 224 kbps 64 kbps
Line Attenuation 46 db 13.5 db
Noise Margin 9 db 3 db
Download speed: 104Kbps Upload speed: 45Kbps IP: xxxxxxxxx ISP: PlusNet Technologies Ltd
Regards
Chris
spraxyt
Resting Legend
Fixes: 75
Those stats are dreadful, both downstream and upstream. With 46dB attenuation your downstream sync (connection) speed should be around 5000kbps rather than the 224kbps you have.
First thing is to establish whether the problem is internal to your property or external. This page gives details of internal checks. It might be helpful to mention that using the BT Availability checker to get an idea of your line's capabilities could give misleading results. That tends to report what you've got now if there is an existing connection - and that is rubbish. You should expect to see connection speeds around 5000kbps.
When checking the effects of any changes, please check sync/connection speeds and don't bother with speed tests. It can be several days before any improvement shows through with those.
David
David
chris2005
Hi
I was doing the checks in my home and phone my mobile phone to check the line and a completely different telephone number was coming up on my mobile phone.
I tried it twice and it was the same thing.  No wonder somebody who tried ringing me the other day said some stranger answered the phone.
I think there must be water in a box after all the heavy rain everything was ok before the wet weather arrived.
chris2005
Yes there deffinetly something wrong with the phone line I just rang my house phone and it rings faintly then some old women answered the phone .
I will have to get this sorted who is the best people to get onto    BT or Plusnet ?
My broadband and phone line are with plusnet
Jaggies
As Plusnet are your phone supplier, report it to them as a crossed line.
jojopillo
Hi chris2005,
I've asked one of our faults guys to check for the latest on this for you.
Jojo Smiley
jojopillo
Hi michael41,
Your profile has now lifted to 2000k so you should be seeing that at your end now.
Jojo Smiley
jojopillo
Hi chris2005,
Apparently the work is scheduled for tomorrow and with this type of fault we expect the engineer to resolve this externally rather than have to visit your property.
Jojo Smiley
