Broadband speeds dropped massively
- Broadband speeds dropped massively
02-12-2007 3:54 PM
Over the last week or so i have noticed my broadband speed drop dramatically. Using the speed test on the Plus connection settings, i used to get about 3000 kbps but now i'm only reaching 470 kbps. The high speed broadband service is saying i have a current sync speed of 500kbps, however my linksys router is stating that i have a downstream rate of 3712 Kbps.
Anybody got any ideas?? I've tried connecting directly to the router using an ethernet cable, and tried another machine but it makes no difference!
Many thanks
Many thanks
Message 1 of 8
(1,878 Views)
7 REPLIES 7
Re: Broadband speeds dropped massively
02-12-2007 4:01 PM
There have been a number of disconnections shown in your connection logs after fairly short connections. This is normally down to noise on the line causing the issues, as such I'd recommend that you test the connection from the master BT socket (where the phone line comes into your house) with all other items in other sockets removed.
If disconnections stop, plug the other items back in one by one and see if there is anything in particular causing the issue.
If the disconnections are ongoing then it would seem to be a line fault - please raise this to us via the checker at http://faults.plus.net and we'll investigate further for you.
Hope that helps,
Hope that helps,
Message 2 of 8
(696 Views)
02-12-2007 5:42 PM
One thing that may have helped cause the problems are the fairly wet weather we've been having ... I believe that can affect noise on the line ...
However, if you are getting a stable service from the master socket then the answer is more than likely in your own wiring. FOr some reason DSL Max seems more demanding on internal wiring ...
Message 3 of 8
(696 Views)
02-12-2007 5:44 PM
I have tried just connecting the router to the master socket without anything else plugged in. However it did not seem to make any difference.
I have now registered a fault with plus so shall have to wait and see.
Message 4 of 8
(696 Views)
03-12-2007 10:27 AM
I've just replied to your fault ticket.
From this end, it's looking a lot more stable, with your current connection having been established 15 hours ago. You're also syncing above 5Mbps, so you should see a considerable improvement in speed in a couple of days.
Message 5 of 8
(696 Views)
05-12-2007 8:27 PM
Cheers for looking into that!
I have noticed my broadband speed is reporting a 3500 kbps sync, much better than the 500 kbps it was reporting yesterday! How long does it usually take for that speed to come into effect as im still only getting about 470kbps on the speed test.
Thanks again!
Thanks again!
Message 6 of 8
(696 Views)
06-12-2007 9:56 AM
If you reboot your router, you speeds should improve.
Message 7 of 8
(696 Views)
06-12-2007 11:23 AM
Thank you, i will try that once i get home!
Thanks for all your help, fantastic customer service as always!
Message 8 of 8
(696 Views)
