Broadband speeds a fifth of what they were, having moved back to Plusnet.
elsmandino
I would be really grateful for some general advice on my ADSL connection.
For as long as I have broadband, I have always had a speed of between 4 and 5 Mbps - various websites have shown that this is slower than many of the other people in my area.  I did, however, accept this as it was enough.
I used Plusnet, without problems, two years ago but moved over to Talktalk as they offered me a better deal, when the contract ended.
However, Plusnet  tempted me back in July of this year.
Over the past few months, I have noticed that my speeds were slowing down and decided to do a speed test - it was 0.85 Mbps.
I tried swapping the ADSL filter and the cable between the filter and the router with spares but neither helped the speeds much.
I also tried resetting the router itself but this did not help either.
Is there any way I can do any tests to find out what has happened?
It would be great to at least narrow things down to whether the problem lies with me or Plusnet.
2 REPLIES 2
DialupDSL
Re: Broadband speeds a fifth of what they were, having moved back to Plusnet.
Hi Sorry to hear your having issues with your connection I found a lot of useful information and links to BT checks on the following web site:
http://www.kitz.co.uk/adsl/bttest.htm
Mustrum
Fixes: 77
Have a look on the Help Pages. Start with the phone checks and dial 17070 and do a quiet line test, you won't get decent speeds if your phone line is not working properly.
