Broadband speed
jeremygray
Broadband speed
I live in Shropshire so the BB speed is not brilliant. About ".2.00mb. I would like to stream films but the speed is not consistent enough. Any ideas would be much appreciated.
Thank you
Fixes: 62
Re: Broadband speed
Please post the information requested here and we may have a better idea http://community.plus.net/forum/index.php/topic,96155.0.html
Re: Broadband speed
Hi jeremygray,
I've checked your connection and you should be seeing speeds of a around 4Mb/s, is your connection you're using a wired or wireless one?
Chris
jeremygray
Re: Broadband speed
Hi having just checked the speed it is today at 11.36 am 4.27mb which is good. Do you think that is fast enough to stream films from Lovefilm as it may not be consistent especially in the evenings?
Thank you for your help.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Broadband speed
That should be fine to stream in Standard Definition. You might have problems if you try to stream High Definition content though.
If you're having any problems streaming, please do let us know though.
Chris Pettitt
Cloud Environments Engineer
Fixes: 4
Re: Broadband speed
@ jeremygray try the iplayer tester http://www.bbc.co.uk/iplayer/diagnostics this should give you a better idea.
jeremygray
Re: Broadband speed
Many thanks for your help which is appreciated.
jeremygray
Re: Broadband speed
Many thanks.
