Broadband speed
DieselSheff
Broadband speed
Hi. i requested my upload speed to be uncapped last month that has gone upto 0.8meg but my download is suffering because of it with it going down to 4 meg from 8-9 is this normal?
Fixes: 62
Re: Broadband speed
no it isn't
please provide the information requested here http://community.plus.net/forum/index.php/topic,96155.0.html
DieselSheff
Re: Broadband speed
I ran the bt test upload is 0.89 and download has gone down to 3.9
jim:red All caps removed as per Forum Rule mod:end
DieselSheff
Re: Broadband speed
DSL Connection
Link Information
Uptime: 0 days, 21:54:54
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.172 / 4.293
Data Transferred (Sent/Received) [GB/MB]: 1,48 /
DieselSheff
Re: Broadband speed
Uptime: 0 days, 21:55:15
Data Transferred (Sent/Received) [GB/GB]: 11,98 / 21,40
IP Address: 91.125.137.34
Primary DNS: 212.159.6.10
Secondary DNS: 212.159.6.9
Fixes: 62
Re: Broadband speed
I need the rest of it - noise margin and attenuation
DieselSheff
Re: Broadband speed
Quote from: Oldjim
DSL Connection
Link Information
Uptime: 0 days, 21:58:46
Data Transferred (Sent/Received) [GB/MB]: 1,48 / 387,58
Output Power (Up/Down) [dBm]: 12,5 / 0,0
Line Attenuation (Up/Down) [dB]: 17,0 / 33,5
SN Margin (Up/Down) [dB]: 6,2 / 6,3
Loss of Framing (Local/Remote): 257 / 0
Loss of Signal (Local/Remote): 31 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 47.255 / 97
FEC Errors (Up/Down): 0 / 158.574
CRC Errors (Up/Down): 174 / 2
HEC Errors (Up/Down): 166 / 30 this?
Fixes: 62
Re: Broadband speed
Something is badly wrong but I have no idea what
Hopefully a member of staff will spot this and advise.
Raising a speed fault may be necessary but hang fire to see it it is picked up here
Do you have a Plusnet supplied router - if so you could try running Routerstats and seeing what the bit loading is like http://www.vwlowen.co.uk/internet/files.htm
DieselSheff
Re: Broadband speed
So in laymans terms my internets fucked up lol? are any staff patrolling the forum today that could help me out?
DieselSheff
Re: Broadband speed
I Tried that software on every router setting they had nd jack came up usernme and password both correct and nothing came up the blue bar went asif was loading then stopped and nothing showed on any of the toolbars
Fixes: 62
Re: Broadband speed
This is what you should be putting in
DieselSheff
Re: Broadband speed
DONE THAT MATE IT SAYS SERVER STOPPED IN CAPITAL RED
Fixes: 62
Re: Broadband speed
Have you enabled telnet - if you are using Windows Vista or 7 http://community.plus.net/library/dns/how-to-change-the-default-dns-servers-in-a-thomson-speedtouch-...
As an aside - please stop posting in all CAPS
DieselSheff
Re: Broadband speed
Ant got a clue mate tbh think ill have to phone em or wait till a member of staff picks this up . could you forward this to a member of staff please/
Fixes: 62
Re: Broadband speed
There won't be any on until Monday
Your best thing is to raise a sped fault here https://faults.plus.net
