Broadband speed
- Re: Broadband speed
Broadband speed
16-04-2013 11:09 AM
I live in Shropshire so the BB speed is not brilliant. About ".2.00mb. I would like to stream films but the speed is not consistent enough. Any ideas would be much appreciated.
Thank you
Thank you
Message 1 of 8
(1,342 Views)
7 REPLIES 7
Re: Broadband speed
16-04-2013 12:15 PM
Please post the information requested here and we may have a better idea http://community.plus.net/forum/index.php/topic,96155.0.html
Message 2 of 8
(670 Views)
Re: Broadband speed
16-04-2013 12:45 PM
Hi jeremygray,
I've checked your connection and you should be seeing speeds of a around 4Mb/s, is your connection you're using a wired or wireless one?
Chris
Chris
Message 3 of 8
(670 Views)
Re: Broadband speed
18-04-2013 11:37 AM
Hi having just checked the speed it is today at 11.36 am 4.27mb which is good. Do you think that is fast enough to stream films from Lovefilm as it may not be consistent especially in the evenings?
Thank you for your help.
Message 4 of 8
(670 Views)
Re: Broadband speed
18-04-2013 11:44 AM
That should be fine to stream in Standard Definition. You might have problems if you try to stream High Definition content though.
If you're having any problems streaming, please do let us know though.
Message 5 of 8
(670 Views)
Re: Broadband speed
18-04-2013 11:49 AM
@ jeremygray try the iplayer tester http://www.bbc.co.uk/iplayer/diagnostics this should give you a better idea.
Message 6 of 8
(670 Views)
Re: Broadband speed
21-04-2013 6:22 PM
Many thanks for your help which is appreciated.
Message 7 of 8
(670 Views)
Re: Broadband speed
21-04-2013 6:23 PM
Many thanks.
Message 8 of 8
(670 Views)
