Broadband speed
Hightower69
Broadband speed
Quick poll, is it acceptable to have download speeds of 0.7? Answers on a postcard!
37 REPLIES 37
adamwalker
Fixes: 221
Re: Broadband speed
FYI you can actually set up a poll, however I'm guessing you're having an issue that's causing slow speeds?
 Adam Walker
Hightower69
Re: Broadband speed
An issue that's been going on for 5 months, it's a joke I'm paying for a service and I have to do all the work
adamwalker
Fixes: 221
Re: Broadband speed
I'm sure our faults team will look into it in due course and I'm more than sure we can help improve this for you.
EDIT: In fact I've just checked your account and noticed that the BT IP profile has increased a little so I've bumped the profile up on our side so it should be around 900-950kbps now. However we'll continue to investigate and see if there's any further improvement we can make to that.
 Adam Walker
Hightower69
Re: Broadband speed
To be honest with you mate I'm losing faith in your faults team, it's gone up to 0.71, before the problems I was getting 2.1, every service provider says I should get at least 1.5 I would kill for that at the moment, it's a joke, my mobile Internet is faster
jelv
Fixes: 10
Re: Broadband speed
Quote from: Hightower69
If you are a very long way from the exchange 0.7 might be an excellent speed! We really need to know more to sensibly comment.
We can help if you post the information asked for here: http://community.plus.net/forum/index.php/topic,96155.0.html
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Hightower69
Re: Broadband speed
Thanks jelv seen it done it got tshirt to prove it, had engineer out he says my line should support 2mb, my neighbours all get 1.5 and above, news flash it gone up to 0.9 abit more and bbc I player might not sound like Norman collier!
jelv
Fixes: 10
Re: Broadband speed
Your line might not follow the same route as your neighbours so a direct comparison might not be valid. There's quite a number of fellow users on here that have helped a lot of people get their issues sorted. Bear with us and post the information and we'll see what we can do.
Hightower69
Re: Broadband speed
Some results here
jelv
Fixes: 10
Re: Broadband speed
You appear to be a long way from the exchange so your speeds will never be brilliant (until fibre becomes available to you). Also your line will be more susceptible to problems.
Have you got a master socket with a removable lower half? If so the same stats when the router is plugged in to the test socket inside the master socket would be helpful.
I note also that the up time is not much more than an hour. Is that a reconnect you did or do you get a lot of disconnections?
Hightower69
Re: Broadband speed
It's always been in the test socket,sometimes it does drop out but not very often, I appreciate I'm never going to get super fast speeds, when it was up near 2 it was liveable but 0.7 is crap
jelv
Fixes: 10
Re: Broadband speed
Are you using any extension leads?
ReedRichards
Seasoned Pro
Fixes: 25
Re: Broadband speed
Edit: Sorry, I think I misunderstood your answer.
jelv
Fixes: 10
Re: Broadband speed
Do you have any other extensions and is anything using them?
Hightower69
Re: Broadband speed
No other extensions, I've changed the filters, tried a different router, done a rain dance etc, lol, surely in the 21st century I can have a bit more speed, my neighbours had the same problem with another supplier, running at 0.7. It took them months of phOne calls letter writing, they even wrote to the CEO, before something was done now they get 1.7 on average, so it is possible
