Broadband speed up & down
- Broadband speed up & down
Re: Broadband speed up & down
30-11-2014 11:30 PM
We all learn something new each day...
02-12-2014 3:08 PM
02-12-2014 7:42 PM
02-12-2014 9:09 PM
Uncapping the upstream of your broadband is unlikely to reduce your download speed or make the connection less stable. It probably won't solve a wireless issue, but it's usually worth having done anyway for the faster upload speed.
03-12-2014 4:09 PM
Sorry to hear that you're having sped issues there Bob, after reviewing your account and the speed profiles we have set for you in various places, it certainly looks like everything is stable on our side here so it looks like ejs and Townman are leading you down the correct path of investigation where the wireless connection is concerned.
I wonder if you're able to have a dig around on Google to find out the vendor of the wireless equipment in the laptop and see if this is a common issue with the model/version of wireless card the laptop is running. Do you know the make and model of the laptop you're using?
As for the uncapping of the upload speed, there is a slight chance of a negligible reduction in speed when uncapping the upload but given your lines characteristics, I wouldn't think you would see any kind of impact from this at all. It certainly shouldn't make it unstable in any way given its performance so if you would like us to uncap this for you, then just let us know.
03-12-2014 4:15 PM
Great to see you back on the forums - have you (quietly) returned to fill the gap left by Linn? I could be a reoccurring theme "I'll be back...!"
How are things going in the new role?
Thank you for clarifying the suggestion made to Bob by the agent - saved me having to ask for clarification... as you suggest though there is a small possibility of a slight impact on the DS speed, it should not be confused with other technology options / configurations in which US "uncapping" does consume "space" otherwise allocated to the DS bandwidth. I think that the advice given by agents might need some "reshaping".
Kevin
03-12-2014 9:28 PM
I hope I wont be back lol
03-12-2014 10:09 PM
03-12-2014 10:24 PM
04-12-2014 12:05 AM
First MAC numbers, no they are not the same. A MAC to migrate is a Migration Authorisation Code, the MAC which you see in insider is a Media Access Control address.
I do hope that you are not thinking of migrating over this issue? If there is a problem with your line (which other than wifi is all that can impact speed) it will move with you if you change ISPs.
As for the change in speed from one minute to the next, then that depends on what is causing the problem - wifi varies from minute to minute. If you are suffering from interference (something we have not explored yet as I did not want to look at complex stuff if we can avoid it) that too can be highly variable.
I am going to review this thread and come back with some suggestions for you to consider.
By the way is it Ossett way that you live? If yes is the bespoke gents tailors Carl Stuart Ltd still in the high street?
Kevin
04-12-2014 8:35 AM
04-12-2014 8:38 AM
04-12-2014 8:48 PM
Sorry about the delay - I've been back through this thread as I think it useful to recap on things. I fear you might have a couple of things going on here, which together are not helping, but individually are only a marginal issue.
Quote from: ossettbob Uptime: 42 days, 16:22:49
Bandwidth (Up/Down) [kbps/kbps]: 444 / 11.445
Line Attenuation (Up/Down) [dB]: 20,5 / 35,5
SN Margin (Up/Down) [dB]: 27,4 / 2,5
Error Seconds (Local/Remote): 8.825 / 0
xDSL session time of 42 days is fairly impressive, especially with the SNRM getting as low as 2.5dB. Can you please keep an eye on these stats - particularly how high / low the SNRM gets and at what time. If you are able spot checks every 3 hours from as early in the day to as late in the day as you can manage would be helpful. At this time of year I expect to see the SNRM fall from around 16:00 as dusk starts to fall and to remain depressed until just after sunrise. What I am interested in finding out is how much the difference is. The error seconds count is less that 0.25% which is very low.
The above points away from an unstable line, however in your recent posts you said...
Quote from: ossettbob My line has been unstable and has temporarily been repaired. Also, looks as if my upload speed has been increased. ... The technical guys must have been working on my fault today as even my PC couldn`t connect to any sites.
Do you have any details of what the tech guys claimed was wrong and what have they done - "temporarily been repaired"?
Quote from: Adam ...after reviewing your account and the speed profiles we have set for you in various places, it certainly looks like everything is stable on our side here so it looks like ejs and Townman are leading you down the correct path of investigation where the wireless connection is concerned.
Adam was covering in here during a training session - he is ex-CRT and knew his stuff - his comment seems at variance with what the tech guys have been saying - doing. Can you please post your current line stats.
Did you find out anything about the laptop's wifi adaptor? What laptop is it please - maybe I can look it up for you?
Quote from: ossettbob Signal levels on others near me (BT) are all 83-91 and all on channel 1..... I`ll try mine on different channels.
What channel did you switch to? What was the result / signal levels?
Quote from: ossettbob By the way, the signal strength on my laptop is now 78, As I said, it changes all the time.
What was the configuration at this point? WiFi channel / wifi adaptor being used by the laptop?
Quote from: ossettbob I saw a tip on an Acer forum to disable the bluetooth (don`t know what bluetooth is anyway). Just run a test and my download speed is between 8&9 Mbs at the moment which is great.
Again, what was the configuration / location of the laptop? Did you get improved results with the laptop taken upstairs?
Carl Stuarts - sad to hear of Nigel's ill health - have around 8 hand made suits from them - shame I have out grown most of them Always excellent service, regardless of if it were my humble self or the King of Dubai or Elton John - they dressed the good and the great!
Kevin
05-12-2014 9:23 AM
You must have had plenty of cash to buy their gear. Think I got a couple of shirts and trousers. Trouble is, they are so good that they go out of fashion. Still got the trousers. Might get turn-ups removed !!!
Thanks for all your help on my problem.
05-12-2014 9:32 AM
Good to learn that you now have a service which you are content with. If you need more help, you know where to find us.
Frankly for a quality suit CS were cheap as chips, not vastly more expensive than off the peg at the high end retailers. Certainly far cheaper than what my dad paid for a not so good made to measure from Richard Burtons. Back in the 90's appearance was everything in my job and as you say the wore well, out lasting 2x off the peg suits... until Matalan came along!
All the best,
Kevin
