Broadband speed up & down
- Broadband speed up & down
28-11-2014 11:26 PM
Re: Broadband speed up & down
28-11-2014 11:32 PM
Link Information
Uptime: 42 days, 16:22:49
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 444 / 11.445
Data Transferred (Sent/Received) [GB/GB]: 1,91 / 1,99
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 20,5 / 35,5
SN Margin (Up/Down) [dB]: 27,4 / 2,5
Loss of Link (Remote): -
Error Seconds (Local/Remote): 8.825 / 0
FEC Errors (Up/Down): 0 / 471.175.513
CRC Errors (Up/Down): 161 / 38.129
HEC Errors (Up/Down): 64 / 362.952
28-11-2014 11:34 PM
There are a number of considerations here - some speed tests are inconsistent - speed tests performed over wifi are as well. If your exchange is suffering congestion, that too can give rise to variable speed test results.
The two speed tests which can be considered dependable are the TBB speed test and the BT Wholesale speed test.
First thing to do is to check that you have the best possible synch speed for your line - which is totally governed by BTOR. Can you please obtain and post the information identified in the speed issues thread at the top of this forum?
Edit - can you add the results of a BT Wholesale speed test and the current speed from the PN portal.
Kevin
28-11-2014 11:43 PM
You are clearly not a heavy user - hardly 2GB in 42 days.
You might benefit from having the US uncapped.
The BT Speed test IP profile and the PN current speed should be around 10Mbps.
29-11-2014 11:15 AM
Download speedachieved during the test was - 0.23 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 10.1 Mbps
Upload speed achieved during the test was - 0.12Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
29-11-2014 11:27 AM
Was that speed test over wifi or Ethernet?
What is the PN portal current speed please?
Kevin
29-11-2014 11:45 AM
Download 9.2 Mbs
Up 0.38 Mbs
My desktop is running Windows XP. My laptop has recently up=graded to Windows 8.1. I`m thinking about reverting to factory settings on my laptop. What do you think ?
I`m not very good with this stuff and I`m 70 yrs old !!
29-11-2014 12:25 PM
You are doing absolutely fine - indeed very good! The test from the desktop is excellent - 9.2Mbps is near enough for a 10Mbps IP profile.
Briefly and simply your usable speed is determined by...
Synch speed (the speed at which the line can send ones and zeros) - this is governed by the line length (attenuation) and noise margin (SNRM) - 35dB gives 11.7Mbps / 36dB gives 11.1Mbps @6dB SNRM
You have 35.5dB giving 11.4Mbps @2.5dB - looking at the 'spot' figure this is a little low for the SNRM figure. Though there might be room for improvement here, it will take a bit of effort, but we can help you though that.
IP Profile (the maximum speed at which useful data can be sent over the line) - 88.2% of the synch speed - this allows for error correction bits inserted into the data and line management traffic.
Your 11.4Mbps gives you a profile of 10.09449Mbps which BT reports as 10.1Mbps the PlusNET profile (see https://portal.plus.net/my.html?action=data_transfer_speed - you will need to login) should be the same.
The above gets data to your router - it then has to get to your device.
Ethernet (wired) - Typically runs at 100Mbps has a low error rate and has virtually no impact on performance.
WiFi - highly variable speed performance can be sensitive to environment, especially the presence of other wifi stations, which can cause transmission errors.
Effective data speed - the net end to end transfer rate after error corrections / error retransmissions have been dealt with. In some circumstances higher synch rates can lead to lower effective data transfer rates due to the proportion of error retransmissions.
The desktop test suggests there is nothing too much wrong with the ADSL service.
Is the laptop wifi connected?
Was it wifi connected before when on WinXP? Do you recall what the speeds were like then?
My experience of Win8/8.1 is limited (I don't like it!) but I have not seen anything to give me concerns about wifi performance. How old is the laptop?
If you are game, there are a few things worth exploring before doing a factory rest.
Kevin
29-11-2014 12:40 PM
29-11-2014 12:57 PM
You should ask to have your upstream uncapped as well. You should see a notable uplift in performance.
29-11-2014 1:01 PM
Might I suggest you holding off the rebuild a while?
Can you do a search for the free version (V3) of inSSIDer.
It is a software tool for looking at wifi networks. We might be able to fix your issue just by changing the wifi channel on your router.
Kevin
29-11-2014 2:02 PM
It`s running. What does it tell me ?
Bob
29-11-2014 2:25 PM
That was quick!
Upper left it lists all of the wifi stations your laptop can see. The one you are connected to will gave a typical wifi icon on it. If you cluck that line, on the right you will see the details...
Signal strength, channel, no co-channel stations, no. over-lapping channels.
At the bottom you see a plot of all channels.
Ideally you need to get on a channel of your own and not overlapping with any other.
Next best is to be the strongest on your channel and not overlapping.
There after be the strongest on where you can.
Look at all the information and see if there is a better channel for you than where you are. If there is, then note that number. Aim for one of 1, 6 or 11. See http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml for more info.
Log into the router and go to the wifi setup and change the current channel (or auto) to the identified number. Cluck save.
There will be a short break in the laptop connection whilst the channels change. You will see this on the plots.
Note when you change your channel other stations might shift too - this might cause the 'spectrum' to tidy up a bit.
If you don't understand anything please ask.
Kevin
30-11-2014 10:17 AM
Just running programme now. Not much oif a clue what it means.
Signal -69db
Channel 1
Link Score 56
Co-Channel 3
No overlapping
Bob
30-11-2014 10:31 AM
Signal -81db
Channel 1
Link Score 40
Co-Channel 0
No overlapping
