Broadband speed too slow last few days
- Re: Broadband speed too slow last few days
03-02-2015 10:08 AM
This from Router:
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 31395 37769 0 9214 22125 00:20:40
LAN 10M/100M 19199 13862 0 10299 3568 00:21:13
WLAN 11M/54M 28196 23253 0 12759 6119 00:21:03
ADSL Link Downstream Upstream
Connection Speed 573 kbps 445 kbps
Line Attenuation 24 db 5.5 db
Noise Margin 31 db 25 db
This from BT Speed Test:
1. Best Effort Test:
Download Speed : 0.51 Mbps
2. Upstream Test:
Upload Speed : 0.35 Mbps
Have tried everything. Has been slow since loss of broadband Friday evening (31st January); can someone look to see if something has been reset somewhere?
03-02-2015 1:31 PM
Your line is disconnecting a lot, is the router plugged into the master socket via a filter?
I'd suggest reporting this as a fault to us here https://faults.plus.net
03-02-2015 2:12 PM
Is that issue? is this DLM that has changed my profile?
03-02-2015 2:24 PM
Although there aren't as many disconnections showing today, there are still a few and resetting the line while it's still disconnecting could just make it worse again. If I was to reset the line, I couldn't do it again within 10 days.
Let me know if you'd like to try the reset, or get this looked into as a fault.
03-02-2015 2:30 PM
I guess best for me to wait till DLM updates my profile? (and leave router alone?!)
03-02-2015 2:32 PM
03-02-2015 2:38 PM
03-02-2015 2:46 PM
I'll give BT Speedtest a go also.
Thanks very much.
03-02-2015 2:56 PM
Connection Speed 13434 kbps 448 kbps
Line Attenuation 25 db 5.5 db
Noise Margin 6 db 28 db
BT Speedtest
Download Speed : 11.47 Mbps
2. Upstream Test:
Upload Speed : 0.36 Mbps
03-02-2015 3:37 PM
03-02-2015 5:48 PM
04-02-2015 9:57 AM
06-02-2015 1:57 PM
DownStream Connection Speed 13194 kbps
UpStream Connection Speed 448 kbps
06-02-2015 4:18 PM
Let me have a dig.
06-02-2015 4:28 PM
